楼主: lidicn
[插件集成] 斐讯K3官Root【更新】【设备追踪】【device tracker】插件
发表于 2018-9-25 01:26:58 | 显示全部楼层
真是厉害了,表示密切关注!
发表于 2018-10-22 16:14:43 | 显示全部楼层
学习学习
发表于 2018-10-24 17:32:31 | 显示全部楼层
应该需要吧
发表于 2018-10-29 00:10:23 | 显示全部楼层
entware可以吗
发表于 2018-11-4 14:39:49 | 显示全部楼层
看看这个怎么样的
发表于 2018-11-8 13:46:33 | 显示全部楼层
官改固件来学习下
发表于 2018-11-8 14:03:19 | 显示全部楼层
谢谢分享,谢谢
发表于 2018-11-8 17:07:40 | 显示全部楼层
docker安装的。
__pycache__里面已经产生了phicomm_k3.cpython-36.pyc,感觉是应该运行了,结果还是无法启动
发表于 2018-11-8 22:47:41 | 显示全部楼层
应该就是L大你说的安装paramiko错误,但是我也外安了lib俩,还是出错,难道docker有影响?
Unable to install package pexpect==4.0.1: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0xffffb48a89b0>: Failed to establish a new connection: [Errno -3] Try again',)': /simple/pexpect/
  Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0xffffb48a8518>: Failed to establish a new connection: [Errno -3] Try again',)': /simple/pexpect/
  Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0xffffb48a8828>: Failed to establish a new connection: [Errno -3] Try again',)': /simple/pexpect/
  Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0xffffb48bd2b0>: Failed to establish a new connection: [Errno -3] Try again',)': /simple/pexpect/
  Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0xffffb48bd5f8>: Failed to establish a new connection: [Errno -3] Try again',)': /simple/pexpect/
  Could not find a version that satisfies the requirement pexpect==4.0.1 (from versions: )
No matching distribution found for pexpect==4.0.1
You are using pip version 18.0, however version 18.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
发表于 2018-11-8 23:37:01 来自手机 | 显示全部楼层
我要安装
GMT+8, 2026-1-14 06:09 , Processed in 0.133016 second(s), 10 queries , MemCached On.
