楼主: huang7dede
[流程系列] [node-red][0901更新]微信语音远程大喇叭,给家里人远程喊话
 火.. [复制链接]
发表于 2021-8-22 12:32:38 来自手机 | 显示全部楼层
还是不会把生成的文件图推送到音箱播放
 楼主| 发表于 2021-8-22 17:12:31 | 显示全部楼层
ilongjiang 发表于 2021-8-22 12:32
还是不会把生成的文件图推送到音箱播放
播放方式太多,,什么DLNA,,小爱同学,,蓝牙连接,,mpd,,小度好像也可以dlna,所以得根据自己的实际情况搭配
不会linux下播放音乐那就没办法了.
其实论坛那么多教程
我是直接插的最普通的10元钱有线小音箱到主板插孔,,安装alsa,和mpd播放
发表于 2021-8-22 17:18:58 | 显示全部楼层
为什么文件都是1K
 楼主| 发表于 2021-8-22 17:22:56 | 显示全部楼层
fpsonic 发表于 2021-8-22 17:18
为什么文件都是1K
把你这个流程导出来,我导入看看,,,记得把微信设置瞎写,别泄露了.
发表于 2021-8-22 17:52:07 | 显示全部楼层
[{"id":"94e222e9.2ca878","type":"file","z":"e5e0dd35.3d985","name":"保存路径","filename":"/config/www/weixin_audio/fpsonic1.amr","appendNewline":false,"createDir":false,"overwriteFile":"true","encoding":"none","x":840,"y":320,"wires":[[]]}]
发表于 2021-8-22 17:55:28 | 显示全部楼层
[{"id":"e5e0dd35.3d985","type":"tab","label":"流程 1","disabled":false,"info":""},{"id":"607d2355.abfc2c","type":"bizwechat-input","z":"e5e0dd35.3d985","name":"","bizwechat":"2002b661.ad5142","x":130,"y":220,"wires":[["965ffd1d.edcc9"]]},{"id":"965ffd1d.edcc9","type":"switch","z":"e5e0dd35.3d985","name":"判断是否语音","property":"message.MsgType","propertyType":"msg","rules":[{"t":"eq","v":"voice","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":340,"y":220,"wires":[["10191e6d.a25c6a"]]},{"id":"10191e6d.a25c6a","type":"function","z":"e5e0dd35.3d985","name":"","func":"var access_token = global.get('wechat-1000004'); //wechat-1000003改成自己的,在上下文菜单的全局里找\nvar media_id = msg.message.MediaId;\nvar url = \"https://qyapi.weixin.qq.com/cgi-bin/media/get\"\nmsg.url = url + '?access_token' + access_token + '&media_id=' + media_id ;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":180,"wires":[["f1ea52a0.067a78"]]},{"id":"f1ea52a0.067a78","type":"http request","z":"e5e0dd35.3d985","name":"下载","method":"POST","ret":"bin","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":650,"y":280,"wires":[["94e222e9.2ca878"]]},{"id":"94e222e9.2ca878","type":"file","z":"e5e0dd35.3d985","name":"保存路径","filename":"/config/www/weixin_audio/fpsonic1.amr","appendNewline":false,"createDir":false,"overwriteFile":"true","encoding":"none","x":840,"y":320,"wires":[[]]},{"id":"2002b661.ad5142","type":"bizwechat-configurator","name":"发帖用","port":"36666","corpid":"dfadaaf","agentid":"dfeeeggg","corpsecret":"dasfadfas","url":"http://","token":"fffffe","aeskey":"aaaaaa","client_id":"","client_secret":""}]
发表于 2021-8-23 02:14:00 | 显示全部楼层
楼主 这个微信喇叭功能非常好!可是遇到和其他网友一样的问题,设置好了,也都正常使用了,可是默默奇妙会不知道什么时候会无法播放语音,排查后发现录音文件我的无论怎么录音都是4K大小,call service调用时提示api 错误,就是这个录音文件肯定有问题了,删除它,重新录音还是能录音,不过大小依旧是4k,网友是始终为1k,看来是普遍现象,楼主使用中有出现这个问题吗,请帮我们大家排查下,找到原因解决它啊,目前测试重启nr或者ha是无效的,好像企业微信我发了几个文本测试再发送语音又好像,也不知道怎么调试好的,请解决谢谢!
 楼主| 发表于 2021-8-23 07:54:39 | 显示全部楼层
fpsonic 发表于 2021-8-22 17:55
[{"id":"e5e0dd35.3d985","type":"tab","label":"流程 1","disabled":false,"info":""},{"id":"607d2355. ...
看到了,,,你的http request节点的请求方式为啥要改成POST,,,我的例子里明明是GET啊
改回来先
 楼主| 发表于 2021-8-23 07:55:56 | 显示全部楼层
wangmucha 发表于 2021-8-23 02:14
楼主 这个微信喇叭功能非常好!可是遇到和其他网友一样的问题,设置好了,也都正常使用了,可是默默奇妙会 ...
看一下http request请求方式,,,不是POST,,是GET,,检查一下.....
发表于 2021-8-23 09:27:06 | 显示全部楼层
GMT+8, 2026-1-18 17:32 , Processed in 0.094179 second(s), 3 queries , MemCached On.
