楼主: 27hh
[修仙教程] 【持续更新优化】小米米家智能设备通用接入HomeAssistant插件
27hh
教程狂人论坛风云人物
 楼主| 发表于 2021-1-27 00:01:49 | 显示全部楼层
skika 发表于 2021-1-24 21:43
还有 philips.light.moonlight
没有看到你贴的报错信息
发表于 2021-1-27 00:07:46 | 显示全部楼层
27hh 发表于 2021-1-27 00:01
没有看到你贴的报错信息
贴在你另外一个贴那里了
philips.light.cbulb
siid 2: Light
   piid 1: Switch Status 可读取 可控制
      数据类型:bool
   piid 2: Brightness 可读取 可控制
      数据类型:uint8
      取值范围:[1, 100, 1]
   piid 3: Color 可读取 可控制
      数据类型:uint32
      取值范围:[0, 16777215, 1]
   piid 4: Color Temperature 可读取 可控制
      数据类型:uint32
      取值范围:[1882, 7000, 1]
   piid 5: Mode 可读取 可控制
      数据类型:uint8
      取值范围:
         0: None
         1: Reading
         2: Warmth
         3: Night
         4: Color
设置如下:
- platform: xiaomi_miot_raw
    host: 192.168.
    token:
    mapping:
      switch_status:
        siid: 2
        piid: 1
      brightness:
        siid: 2
        piid: 2
      color:
        siid: 2
        piid: 3
      color_temperature:
        siid: 2
        piid: 4
      mode:
        siid: 2
        piid: 5
    params:
      switch_status:
        power_on: True
        power_off: False
      brightness:
        value_range: [1, 100, 1]
      color:
        value_range: [0, 16777215, 1]
      color_temperature:
        value_range: [1882, 7000, 1]
      mode:
        0: None
        1: Reading
        2: Warmth
        3: Night
        4: Color
报错如下:
xiaomi_miot_raw: Error on device update!
  File "/opt/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 359, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/opt/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 466, in async_device_update
    await task
  File "/home/homeassistant/.homeassistant/custom_components/xiaomi_miot_raw/light.py", line 214, in async_update
    self._color_temp = color.color_temperature_kelvin_to_mired(self._state_attrs['color_temperature'])
  File "/opt/homeassistant/lib/python3.7/site-packages/homeassistant/util/color.py", line 515, in color_temperature_kelvin_to_mired
    return math.floor(1000000 / kelvin_temperature)
ZeroDivisionError: division by zero
发表于 2021-1-27 21:15:03 | 显示全部楼层
lee869882 发表于 2021-1-11 18:23
雲儀開窗器有組件了~
https://github.com/dominic2708/yunyi_windows
感谢分享!正好有需求。
发表于 2021-1-28 01:34:07 | 显示全部楼层
bomb40 发表于 2021-1-25 21:01
试了一下,邦先生m1s也出现了-9999的错
有时间我好好研究一下,感谢大佬的分享!
我用这个插件一直接入不了,用另外帖子的自动接入就可以
27hh
教程狂人论坛风云人物
 楼主| 发表于 2021-1-28 12:32:38 | 显示全部楼层
skika 发表于 2021-1-27 00:07
贴在你另外一个贴那里了
philips.light.cbulb
发生错误的原因:获取到的色温为0,无法转换,因此发生错误。可能是因为你的灯泡设计不规范。把配置文件的两个 color_temperature 删除吧
发表于 2021-1-28 22:26:38 | 显示全部楼层
27hh 发表于 2021-1-28 12:32
发生错误的原因:获取到的色温为0,无法转换,因此发生错误。可能是因为你的灯泡设计不规范。把配置文件 ...
这个是米家飞利浦彩光灯泡。而米家飞利浦的台灯都不行,用miio的可以
发表于 2021-1-28 23:05:53 | 显示全部楼层
怎么的集成里面没有Miot呢?已经下载到文件夹了
发表于 2021-1-29 00:30:10 | 显示全部楼层
同样集成里面没有miot
27hh
教程狂人论坛风云人物
 楼主| 发表于 2021-1-29 01:33:15 | 显示全部楼层
下载后需要重启HA并清空浏览器缓存。
27hh
教程狂人论坛风云人物
 楼主| 发表于 2021-1-29 01:33:18 | 显示全部楼层
lipwah 发表于 2021-1-29 00:30
同样集成里面没有miot
下载后需要重启HA并清空浏览器缓存。
GMT+8, 2026-1-16 05:28 , Processed in 0.054589 second(s), 10 queries , MemCached On.
