楼主: 27hh
[修仙教程] 【持续更新优化】小米米家智能设备通用接入HomeAssistant插件
发表于 2022-1-1 03:05:41 | 显示全部楼层
通过绑定其他平台同步过来的设备能用么?
发表于 2022-2-4 00:09:17 | 显示全部楼层
希望接入 FIVE紫外线灯的
发表于 2022-2-26 23:32:32 | 显示全部楼层
大神。我目前有这么一个问题。我添加设备以后如果直接在HA的APP里面控制开关可以瞬间有响应。在本地实体开关要过5到20秒才有响应。这个要怎么解决呢?
发表于 2022-5-27 01:15:40 | 显示全部楼层
红外线遥控连入的空调,新增温度感应器为正确温度,似乎都不会成功,这情况都没有其他人遇到吗?
发表于 2023-7-27 13:32:29 | 显示全部楼层
楼主大神,帮我看一下这个是怎么回事呢,我看设备好像都读取到了,不知道是那里有问题。
Logger: homeassistant.config_entries
Source: util/file.py:70
First occurred: 13:19:04 (2 occurrences)
Last logged: 13:24:17
Error setting up entry Xiaomi: 109923438 for xiaomi_miot
  File "/usr/src/homeassistant/homeassistant/util/file.py", line 67, in write_utf8_file
    os.replace(tmp_filename, filename)
OSError: [Errno 22] Invalid argument: '/config/.storage/xiaomi_miot/tmpz4idyx0n' -> '/config/.storage/xiaomi_miot/urn:miot-spec-v2:deviceutlet:0000A002:chuangmi-212a01:3.json'
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 339, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/config/custom_components/xiaomi_miot/__init__.py", line 235, in async_setup_entry
    await async_setup_xiaomi_cloud(hass, config_entry)
  File "/config/custom_components/xiaomi_miot/__init__.py", line 298, in async_setup_xiaomi_cloud
    hass.data[DOMAIN]['miot_specs'][model] = await MiotSpec.async_from_type(hass, urn)
  File "/config/custom_components/xiaomi_miot/core/miot_spec.py", line 329, in async_from_type
    await store.async_save(dat)
  File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 276, in _async_handle_write_data
    await self.hass.async_add_executor_job(
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 287, in _write_data
    json_util.save_json(
  File "/usr/src/homeassistant/homeassistant/util/json.py", line 68, in save_json
    write_utf8_file(filename, json_data, private)
  File "/usr/src/homeassistant/homeassistant/util/file.py", line 70, in write_utf8_file
    raise WriteError(error) from error
homeassistant.util.file.WriteError: [Errno 22] Invalid argument: '/config/.storage/xiaomi_miot/tmpz4idyx0n' -> '/config/.storage/xiaomi_miot/urn:miot-spec-v2:deviceutlet:0000A002:chuangmi-212a01:3.json'
发表于 2023-12-5 16:48:13 | 显示全部楼层
学习一下,谢谢
发表于 2023-12-6 00:17:59 | 显示全部楼层
感谢大楼分享
发表于 2023-12-6 12:25:30 | 显示全部楼层
感谢楼主分享
GMT+8, 2026-1-16 00:39 , Processed in 0.136772 second(s), 9 queries , MemCached On.
