楼主: leon_xi
[插件集成] 自定义组件 简单接入小米温湿度计2
发表于 2020-12-7 10:48:59 | 显示全部楼层
看看,学习
发表于 2020-12-8 12:15:37 | 显示全部楼层
每次大概重启几分钟后就会断连,是我姿势不对吗
Logger: homeassistant
Source: custom_components/mitemp_bt2/sensor.py:163
First occurred: 下午12:11:10 (1 occurrences)
Last logged: 下午12:11:10
Error doing job: Future exception was never retrieved
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/config/custom_components/mitemp_bt2/sensor.py", line 267, in update_ble
    discover_ble_device(config)
  File "/config/custom_components/mitemp_bt2/sensor.py", line 246, in discover_ble_device
    data = instance.get_info(config[CONF_MAC], mode=config[CONF_MODE])
  File "/config/custom_components/mitemp_bt2/sensor.py", line 163, in get_info
    p.writeCharacteristic(0x0046,b'\xf4\x01\x00',True)
  File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 543, in writeCharacteristic
    return self._getResp('wr')
  File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 407, in _getResp
    resp = self._waitResp(wantType + ['ntfy', 'ind'], timeout)
  File "/usr/local/lib/python3.8/site-packages/bluepy/btle.py", line 362, in _waitResp
    raise BTLEDisconnectError("Device disconnected", resp)
bluepy.btle.BTLEDisconnectError: Device disconnected
发表于 2020-12-8 12:35:11 | 显示全部楼层
现在我遇到的问题也是,一段时间后断连。现在刷新时间设的是15分钟,还是会断
发表于 2020-12-13 12:50:06 | 显示全部楼层
Invalid config for [switch.xiaomi_miio]: value is not allowed for dictionary value @ data['model']. Got 'chuangmi.plug.hmi208'. (See ?, line ?).
请问这是什么情况
stiv
发表于 2020-12-16 20:11:15 | 显示全部楼层
运行一会数据就停止更新了。温湿度数据一直不更新。哪里的bug??
发表于 2021-1-14 20:09:45 | 显示全部楼层
我是通过自定义组件的方式安装的 。编辑完配置文件后 检查配置 一直转圈
过不去 我得Home Assistant 是0.117.6 是怎么回事啊  大佬
 楼主| 发表于 2021-1-14 20:40:16 来自手机 | 显示全部楼层
检查配置可能是你的其它配置需要调用外网吧,这个插件不会这么慢的
发表于 2021-1-17 16:18:46 | 显示全部楼层
搞定了。谢谢
发表于 2021-1-20 00:38:34 | 显示全部楼层
2021-01-20 00:33:31 ERROR (MainThread) [homeassistant.config_entries] Error unloading entry 米家温湿度计 for sensor
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 321, in async_unload
    result = await component.async_unload_entry(hass, self)  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 72, in async_unload_entry
    return await hass.data[DOMAIN].async_unload_entry(entry)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 172, in async_unload_entry
    raise ValueError("Config entry was never loaded!")
ValueError: Config entry was never loaded!
是什么问题 大佬
发表于 2021-1-21 15:50:16 | 显示全部楼层
太棒了,我的群晖docker也能用了
GMT+8, 2026-1-16 19:14 , Processed in 0.740746 second(s), 12 queries , MemCached On.
