楼主: jingqinglee
[基础教程] HACS安装讲解--个人理解
我就是六神
活跃会员教程狂人灌水之王
发表于 2020-5-21 18:24:24 | 显示全部楼层
ufonba 发表于 2020-5-21 16:14
这个是不是需要路由器FQ才能解决
是的!
发表于 2020-6-25 11:24:09 | 显示全部楼层
能卸载吗。出问题了。不想用它了
 楼主| 发表于 2020-6-25 11:25:09 | 显示全部楼层
goldstep 发表于 2020-6-25 11:24
能卸载吗。出问题了。不想用它了
删除目录  删除配置内容
发表于 2020-7-6 10:01:31 | 显示全部楼层
我是首次安装完之后卡好久。
HACS is starting up
HACS is starting up, during this time some information might be missing or incorrect
Background tasks pending
Some repositories might not show untill this is completed
我估摸着也是因为github国内访问慢造成一直没能下载完商店列表
发表于 2020-10-13 09:58:50 | 显示全部楼层
装了也没有用,,HACS里面没有插件可装。。
发表于 2020-11-13 16:59:43 | 显示全部楼层
请问这是什么情况?
Logger: homeassistant.config_entries
Source: custom_components/hacs/operational/setup.py:188
First occurred: 下午4:45:17 (1 occurrences)
Last logged: 下午4:45:17
Error setting up entry for hacs
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 231, in async_setup
    result = await component.async_setup_entry(hass, self)  # type: ignore
  File "/config/custom_components/hacs/__init__.py", line 30, in async_setup_entry
    return await hacs_ui_setup(hass, config_entry)
  File "/config/custom_components/hacs/operational/setup.py", line 62, in async_setup_entry
    return await async_startup_wrapper_for_config_entry()
  File "/config/custom_components/hacs/operational/setup.py", line 87, in async_startup_wrapper_for_config_entry
    startup_result = await async_hacs_startup()
  File "/config/custom_components/hacs/operational/setup.py", line 188, in async_hacs_startup
    async_call_later(hacs.hass, 5, hacs.startup_tasks())
TypeError: startup_tasks() missing 1 required positional argument: '_event'
发表于 2020-12-30 10:21:27 | 显示全部楼层
南柯醉一梦丶 发表于 2020-5-13 19:48
记得改下github的host。。否则。。不建议使用hacs
请问怎么修改  hassio
发表于 2020-12-30 10:31:13 | 显示全部楼层
发表于 2020-12-30 13:47:48 | 显示全部楼层
发表于 2020-12-30 20:30:28 | 显示全部楼层
你确定你这个是docker里面名为Homeassistant的container的hosts文件吗?你编辑其它地方的hosts可没用处。
GMT+8, 2025-12-1 21:00 , Processed in 0.597381 second(s), 14 queries , MemCached On.
