楼主: 671792320
hass.io 入门进阶贴 从启动后到接入mqtt完整记录
发表于 2018-2-9 08:54:36 | 显示全部楼层
13669223769 发表于 2017-12-29 23:23
hass.io如何配置静态IP呢,总是配置不成功啊
静态ip从路由里设置更简单把?把ip和mac绑定
发表于 2018-2-9 14:14:09 | 显示全部楼层
mqtt  服务器 求指引
发表于 2018-2-10 23:33:46 | 显示全部楼层
mqtt  的日志里提示
1518276634: Warning: Mosquitto should not be run as root/administrator.
这个错误什么意思??
starting version 3.2.2
1518276634: mosquitto version 1.4.12 (build date 2017-06-01 13:03:48+0000) starting
1518276634: Config loaded from /etc/mosquitto.conf.
1518276634: Opening ipv4 listen socket on port 1883.
1518276634: Opening ipv6 listen socket on port 1883.
1518276637: New connection from 192.168.0.108 on port 1883.
1518276637: New client connected from 192.168.0.108 as DVES_71C4AB (c1, k15, u'mqtt').
发表于 2018-2-11 10:27:33 | 显示全部楼层
大大
可以請教一下嗎?
我在加入開關燈制時也很順利,但一加入type"fan"時就出問題了
一個新手小白上~
SyntaxError: Unexpected token { in JSON at position 904
    at JSON.parse (<anonymous>)
    at Server._loadConfig (/usr/lib/node_modules/homebridge/lib/server.js:201:19)
    at new Server (/usr/lib/node_modules/homebridge/lib/server.js:57:38)
    at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:26:16)
    at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:635:30)
    at Object.Module._extensions..js (module.js:646:10)
    at Module.load (module.js:554:32)
    at tryModuleLoad (module.js:497:12)
    at Function.Module._load (module.js:489:3)
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat? ... =DNSServiceRegister>
[2018-2-11 10:20:12] Loaded plugin: homebridge-broadlink-rm
[2018-2-11 10:20:12] Registering platform 'homebridge-broadlink-rm.BroadlinkRM'
[2018-2-11 10:20:12] ---
[2018-2-11 10:20:13] Loaded plugin: homebridge-homeassistant
[2018-2-11 10:20:13] Registering platform 'homebridge-homeassistant.HomeAssistant'
[2018-2-11 10:20:13] ---
[2018-2-11 10:20:13] There was a problem reading your config.json file.
[2018-2-11 10:20:13] Please try pasting your config.json file here to validate it: http://jsonlint.com
/usr/lib/node_modules/homebridge/lib/server.js:207
    throw err;
发表于 2018-2-11 13:40:31 | 显示全部楼层
你好,为啥我按你的教程做到最后,报错了
core-ssh:~# mosquitto_sub -u mqtt -P mqtt  -t home/# -v
Error: Address not available
 楼主| 发表于 2018-2-11 23:14:25 | 显示全部楼层
foxfeng 发表于 2018-2-11 13:40
你好,为啥我按你的教程做到最后,报错了
我早就转战docker环境了,所以抱歉无法解答这个问题。
 楼主| 发表于 2018-2-11 23:15:36 | 显示全部楼层
Eddy0clng 发表于 2018-2-11 10:27
大大
可以請教一下嗎?
不过看问题应该是环境出现问题了,翻译下看看。我也是一个小白,常用翻译。有帮助的
发表于 2018-9-1 22:58:11 | 显示全部楼层
bluezym 发表于 2018-2-9 08:52
mqtt属于io系统内置?不需要安装?
文中提到的mqtt配置文件在什么路径下??? ...
同求,感觉出来得莫名其妙
发表于 2018-9-1 23:38:56 | 显示全部楼层
appleftg 发表于 2018-9-1 22:58
同求,感觉出来得莫名其妙
找到了,原来要添加官方Mosquitto broker后在插件配置里修改
发表于 2019-1-20 11:57:34 来自手机 | 显示全部楼层
受教了,谢谢
GMT+8, 2025-12-22 07:57 , Processed in 0.405706 second(s), 12 queries , MemCached On.
