楼主: guy.feng
[插件集成] 新组件 - 阿里域名 alidns
 楼主| 发表于 2020-2-16 19:10:13 | 显示全部楼层
yonghengdeshang 发表于 2020-2-16 15:54
小白一名,请问  domain: yourdomain这一项填什么,我在阿里页里自己买么?
是的,比如 like.com 挺便宜的; subdomain: www, 合起来就是www.like.com
发表于 2020-2-16 21:45:25 | 显示全部楼层
好的,谢谢.阿里没有免费的域名么?花生壳会赠送
发表于 2020-2-17 00:10:12 | 显示全部楼层
花生壳送的难记,但是路由器DDNS都支持花生壳,所以我是
阿里云域名 CNAME -> 花生壳域名 <- 路由器DDNS
发表于 2020-2-17 09:18:33 | 显示全部楼层
学习学习
发表于 2020-2-21 11:26:13 | 显示全部楼层
还有则个。。。支持支持。。一直手动改 解析地址。。。。尽量都不断电重启
发表于 2020-2-21 22:14:15 | 显示全部楼层
阿里的怎么收费呢?
 楼主| 发表于 2020-2-22 20:29:22 | 显示全部楼层
发表于 2020-3-30 22:42:56 | 显示全部楼层
我都没有IPV4的公网,只能摸索IPV6了
发表于 2022-2-17 21:12:21 | 显示全部楼层
没见有alidns呀
发表于 2022-4-16 16:23:40 | 显示全部楼层
楼主你好,这个脚本只能运行在x86平台吗?我在树莓派上提示我、
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/__init__.py:610
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 16:21:23 (2 occurrences)
Last logged: 16:22:55
[2959978608] The system cannot restart because the configuration is not valid: Invalid config for [sensor]: required key not provided @ data['platform']. Got None. (See /config/configuration.yaml, line 41).
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 192, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1636, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1673, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 610, in async_handle_core_service
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Invalid config for [sensor]: required key not provided @ data['platform']. Got None. (See /config/configuration.yaml, line 41).
GMT+8, 2026-1-19 09:07 , Processed in 0.526910 second(s), 14 queries , MemCached On.
