楼主: zxl_hass
[插件集成] 海尔空气盒子接入homeassistant插件发布,支持红外学码和发码
 楼主| 发表于 2021-7-3 22:16:10 | 显示全部楼层
牧星河 发表于 2021-3-23 21:45
那个ssd的传感器表示什么啊?空气盒子的pm2.5没有显示,是根据voc算的值吗? ...
SSD,代表舒适度,根据温湿度算法算出来的,PM2.5是个假的,根本不准,所以就没有增进。
WIFI电表,ZigBee电表 单相 三相
 楼主| 发表于 2021-7-3 22:17:42 | 显示全部楼层
aiqienanguatou 发表于 2020-12-11 13:09
流弊,大佬这个海尔WiFi热水器能接入么
我没有你说的东西,你搜下论坛看看其他人有没有接入过吧
发表于 2021-7-4 10:29:55 | 显示全部楼层
好吧谢谢了
发表于 2021-9-18 07:32:17 | 显示全部楼层
版本        core-2021.9.6
安装类型        Home Assistant Supervised
开发版        false
Supervisor        true
Docker        true
用户        root
虚拟环境        false
Python 版本        3.9.6
操作系统系列        Linux
操作系统版本        5.9.0-arm-64
CPU 架构        aarch64
时区        Asia/Shanghai
好像用不了了
Logger: homeassistant.config
Source: config.py:887
First occurred: 17:28:32 (2 occurrences)
Last logged: 17:28:39
  • Platform error: sensor - Integration 'airbox' not found.
  • Platform error: switch - Integration 'airbox' not found.
ip没错,在海尔智家里面配上网了
 楼主| 发表于 2021-9-18 23:17:37 | 显示全部楼层
梅子青时 发表于 2021-9-18 07:32
版本        core-2021.9.6
开发版        false
manifest.json文件要加版本信息
附件已更新
发表于 2021-9-26 22:53:23 | 显示全部楼层
附件已更新
感谢大佬,已成功。一看见回复就兴冲冲地去尝试了
发表于 2021-9-29 12:02:19 | 显示全部楼层
附件已更新
大佬,我这边运行成功,但是日志里面有一些错误信息,不知道是咋回事,方便的话能给看看吗?(传感器实体有了,虚拟的switch也有,也可以使用)
2021-09-29 11:29:46 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration havcs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-09-29 11:29:46 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration xiaomi_miot_raw which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-09-29 11:29:46 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-09-29 11:29:46 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration colorfulclouds which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-09-29 11:29:46 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration airbox which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-09-29 11:29:59 ERROR (SyncWorker_3) [custom_components.airbox.switch] Set up the AirBox switches.
2021-09-29 11:29:59 WARNING (SyncWorker_3) [custom_components.airbox.switch] Update Switch
2021-09-29 11:30:00 WARNING (SyncWorker_3) [custom_components.airbox.switch] Update Switch
此错误来自自定义集成。
Logger: custom_components.airbox.switch
Source: custom_components/airbox/switch.py:58
Integration: AirBox (documentation)
First occurred: 11:29:59 (1 occurrences)
Last logged: 11:29:59
此错误来自自定义集成。
Source: custom_components/airbox/switch.py:152
First occurred: 11:29:59 (2 occurrences)
Last logged: 11:30:00
Update Switch
 楼主| 发表于 2021-10-24 14:18:51 | 显示全部楼层
梅子青时 发表于 2021-9-29 12:02
大佬,我这边运行成功,但是日志里面有一些错误信息,不知道是咋回事,方便的话能给看看吗?(传感器实体 ...
不好意思,这是我写的调试日志,应该写info的,写成error了,不影响使用的
发表于 2021-12-12 02:45:45 来自手机 | 显示全部楼层
辛苦,盒子终于又有用处了
发表于 2022-1-16 13:01:38 | 显示全部楼层
论坛不是很好协同发布代码,fork到了github上:https://github.com/NullYing/haire-airbox
楼主介意可联系我删除
个人的智慧始终是不够的,如有新的发现,欢迎pull request
GMT+8, 2026-1-14 11:17 , Processed in 0.491131 second(s), 11 queries , MemCached On.
