楼主: fineemb
[插件集成] 智米智能电暖器插件
发表于 2020-2-9 00:47:18 | 显示全部楼层
赞 谢谢分享
发表于 2020-2-9 02:04:28 | 显示全部楼层
谢谢楼主分享
发表于 2020-2-9 02:47:33 | 显示全部楼层
  File "/usr/local/lib/python3.7/site-packages/miio/device.py", line 272, in send
    data, addr = s.recvfrom(1024)
socket.timeout: timed out
The above exception was the direct cause of the following exception:
  File "/config/custom_components/miheater/climate.py", line 58, in setup_platform
    device_info = device.info()
  File "/usr/local/lib/python3.7/site-packages/miio/device.py", line 352, in info
    return DeviceInfo(self.send("miIO.info"))
  File "/usr/local/lib/python3.7/site-packages/miio/device.py", line 310, in send
    return self.send(command, parameters, retry_count - 1)
  File "/usr/local/lib/python3.7/site-packages/miio/device.py", line 313, in send
    raise DeviceException("No response from the device") from ex
miio.exceptions.DeviceException: No response from the device
连接中断。正在重新连接...
请问一般出现这个报错可能是什么原因导致的呢?
 楼主| 发表于 2020-2-10 11:42:50 | 显示全部楼层
Traceback (most recent call las ...
好像没能连接到设备token对不对?
发表于 2020-2-22 15:20:39 | 显示全部楼层
看看,学习一下
发表于 2020-2-22 16:23:27 | 显示全部楼层
ddddddddddddd
发表于 2020-2-23 11:48:54 | 显示全部楼层
看下。。。。
发表于 2020-2-23 15:29:30 | 显示全部楼层
111111111111111111111111111111111
发表于 2020-4-4 05:35:56 | 显示全部楼层
看看好东西
发表于 2020-4-5 21:59:55 | 显示全部楼层
感謝分享~
GMT+8, 2026-1-14 06:16 , Processed in 0.947633 second(s), 12 queries , MemCached On.
