查看: 75167|回复: 52
[插件集成] 智米智能电暖器插件
发表于 2020-2-5 12:46:49 | 显示全部楼层 |阅读模式
智米智能电暖器
hacs_badge
This is a custom component for home assistant to integrate the Smartmi smart heater.
Smartmi_smart_heater
Please follow the instructions on Retrieving the Access Token to get the API token to use in the configuration.yaml file.
Credits: Thanks to Rytilahti for all the work.
功能
zhimi.heater.za1 目前只测试过这个型号, 因为其他型号我没有
  • Sensors
    • hvac_modes: heat,off
    • min_temp
    • max_temp
    • target_temp_step
    • current_temperature
    • temperature
    • curr_tempe
    • power
    • humidity
    • target_temperature
  • Chart
    • Temperature History
  • Services
    • set_hvac_mode
    • set_temperature
TODO
  • 蜂鸣器开关
  • 童锁
  • 恒温设置
  • 延时关机
  • 定时关机
Setup
# configuration.yaml
climate:
  - platform: miheater
    host: 192.168.1.13
    token: a9bd32552dc9bd4e156954c20ddbcb38
Configuration variables:
  • host (Required): The IP of your cooker.
  • token (Required): The API token of your cooker.
  • name (Optional): The name of your cooker.
Platform services
Service climate.set_hvac_mode
Specify the heater mode.
Service data attribute Optional Description
entity_id yes Only act on a specific heater.
hvac_mode yes Specify the heater mode (heat/off).
Service climate.set_temperature
Set the temperature of heater.
temperature yes Set the temperature of heater.
发表于 2020-2-5 12:53:49 | 显示全部楼层
学习学习再学习,谢谢谢谢再谢谢!
发表于 2020-2-5 12:57:51 来自手机 | 显示全部楼层
赞
发表于 2020-2-5 13:03:31 | 显示全部楼层
看看吧,但是不知道小米的可用性够不够
发表于 2020-2-5 16:20:27 | 显示全部楼层
赞 谢谢分享
发表于 2020-2-6 10:53:05 | 显示全部楼层
大神太棒了!!!
发表于 2020-2-6 16:58:02 | 显示全部楼层
可惜了,我的 取暖器型号是:zhimi.heater.za1,不能用
 楼主| 发表于 2020-2-6 19:18:08 | 显示全部楼层
不要难过, 是我错了
文档写错.
发表于 2020-2-6 21:41:27 | 显示全部楼层
赞
olly
发表于 2020-2-7 12:33:59 | 显示全部楼层
請問一下LZ這能接到HOMEKIT嗎?
GMT+8, 2026-1-14 06:18 , Processed in 0.969811 second(s), 11 queries , MemCached On.
