楼主: lqgyt1
[插件集成] 小米一级能效空调接入HA
发表于 2020-1-28 17:35:42 | 显示全部楼层
感谢大佬,我的米家互联网空调(三级能效)成功接入ha,型号为MODEL_MA1 = "zhimi.aircondition.ma1"
做了个简单测试,开/关机按钮空调有声音回馈,但屏幕没亮(可能这个按钮只是关机按钮),开机直接按相应模式按钮就开机了.初步测试各个按钮有响应,辅热按钮有效,在米家可以同步显示打开.再次感谢大佬
发表于 2020-1-28 17:39:59 | 显示全部楼层
lqgyt1 发表于 2020-1-28 15:25
需要先安装python-miio
谢谢,解决了,正好看别的帖子看到了.已经成功将米家互联网空调三级能效接入ha,感谢
发表于 2020-1-30 13:10:50 | 显示全部楼层
需要先安装python-miio
Thu Jan 30 2020 13:08:28 GMT+0800 (中国标准时间)
Update of climate.model_ma1_zhimi_aircondition_ma1 is taking over 10 seconds
米家互联网空调总报错,麻烦看一下
2020-01-30 13:07:25 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.model_ma1_zhimi_aircondition_ma1 is taking over 10 seconds
2020-01-30 13:07:31 WARNING (MainThread) [homeassistant.components.climate] Updating mi_airconditioner climate took longer than the scheduled update interval 0:00:15
2020-01-30 13:07:32 ERROR (SyncWorker_2) [miio.device] Unable to discover a device at address 192.168.0.100
2020-01-30 13:07:32 ERROR (MainThread) [custom_components.mi_airconditioner.ac_m1] Got exception while fetching the state: Unable to discover the device 192.168.0.100
2020-01-30 13:07:51 ERROR (SyncWorker_1) [miio.device] Unable to discover a device at address 192.168.0.100
2020-01-30 13:07:51 ERROR (MainThread) [custom_components.mi_airconditioner.ac_m1] Got exception while fetching the state: Unable to discover the device 192.168.0.100
2020-01-30 13:08:12 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.model_ma1_zhimi_aircondition_ma1 is taking over 10 seconds
2020-01-30 13:08:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.model_ma1_zhimi_aircondition_ma1 is taking over 10 seconds
2020-01-30 13:08:33 WARNING (MainThread) [homeassistant.components.climate] Updating mi_airconditioner climate took longer than the scheduled update interval 0:00:15
发表于 2020-5-4 00:08:43 来自手机 | 显示全部楼层
排个雷,目前需要把文件里的from miio.device import deviceexception换成from .exception import deviceexception 然后把python-miio里的exception.py放到文件夹里,否则会报错。另外想问一下楼主,为啥在历史状态里找不到空调的开关,只有温度,是因为climate组件本身的问题吗
发表于 2020-5-7 11:46:48 | 显示全部楼层
c1空调接入hass ,对hass版本有要求吗
我的hass版本还是104.0
我只需要接入c1,所有我把你附件里的py插件放到这里:
结果检查配置 报错:
Platform error climate.mi_aircondition - Integration 'mi_aircondition' not found.
已经搞定,原来是我在这里少放了几个py插件
一个都不能少
发现一个问题,空调状态时不时会变成不可用
发表于 2020-5-8 10:37:47 | 显示全部楼层
这个比node red接入方便一些
发表于 2020-5-29 16:05:17 | 显示全部楼层
大佬, hass110.3现在不支持这个插件了,
Platform error climate.mi_aircondition - cannot import name 'DeviceException' from 'miio.device' (/usr/local/lib/python3.7/site-packages/miio/device.py)
能否更新一下哦,谢谢
发表于 2020-5-29 17:22:57 | 显示全部楼层
110版后就无效了,期待更新插件!!
发表于 2020-6-3 21:22:51 | 显示全部楼层
怎么说 找不到平台:climate.mi_空调 是什么原因哦
发表于 2020-6-7 14:48:24 | 显示全部楼层
Platform error climate.mi_airconditioner - cannot import name 'DeviceException' from 'miio.device' (/usr/local/lib/python3.7/site-packages/miio/device.py)
help me.pls
GMT+8, 2025-12-24 07:25 , Processed in 0.482737 second(s), 19 queries , MemCached On.
