楼主: hugh_jie
[经验分享] esp8266+esphome控制舵机定时喂狗。。。
发表于 2021-12-20 17:04:43 | 显示全部楼层
老大 请问接入两个电机要怎么写?这样写没反应
# Enable Home Assistant API
api:
  services:
    - service: control_servo
      variables:
        level: float
        level_reset: float
      then:
        - servo.write:
            level: !lambda 'return level / 100.0;'
        - delay: 1s
        - servo.write:
            level: !lambda 'return level_reset / 100.0;'
    - service: control_servo1
      variables:
        level: float
        level_reset: float
      then:
        - servo.write:
        - delay: 1s
        - servo.write:
captive_portal:
servo:
  - id: my_servo
    output: pwm_output
  - id: my_servo1
    output: pwm_output1
output:
  - platform: ledc
    pin: GPIO18
    frequency: 50 Hz
  - platform: ledc
    pin: GPIO19
    frequency: 50 Hz
 楼主| 发表于 2021-12-21 17:40:59 | 显示全部楼层
不知道哇,我之前试过2个不行就没搞了
发表于 2021-12-21 19:48:48 | 显示全部楼层
hugh_jie 发表于 2021-12-21 17:40
不知道哇,我之前试过2个不行就没搞了
看我帖子 可以多个控制了 没啥问题
GMT+8, 2026-1-12 15:14 , Processed in 0.394484 second(s), 6 queries , MemCached On.
