楼主: trz0332
[进阶教程] ESPHOME接入培正电表
发表于 2021-5-2 18:41:12 | 显示全部楼层
[18:34:51](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[18:34:51][C][ota:030]:   Address: 192.168.111.216:8266
[18:34:51][C][api:095]: API Server:
[18:34:51][C][api:096]:   Address: 192.168.111.216:6053
[18:34:55][D][pzemac:049]: PZEM AC: V=223.8 V, I=0.035 A, P=0.8 W,  en=0.0 Wh, F=50.0 Hz, PF=0.10
[18:34:55][D][sensor:092]: 'masterpower_Voltage': Sending state 223.80000 V with 1 decimals of accuracy
[18:34:55][D][sensor:092]: 'masterpower_Current': Sending state 0.03500 A with 3 decimals of accuracy
[18:34:55][D][sensor:092]: 'masterpower_Power': Sending state 0.80000 W with 1 decimals of accuracy
[18:34:55][D][sensor:092]: 'masterpower_Energy': Sending state 0.00200 KwH with 1 decimals of accuracy
[18:34:55][D][sensor:092]: 'masterpower_Frequency': Sending state 50.00000 Hz with 1 decimals of accuracy
[18:34:55][D][sensor:092]: 'masterpower_PowerFactor': Sending state 0.10000  with 2 decimals of accuracy
[18:35:55][D][pzemac:049]: PZEM AC: V=223.3 V, I=0.035 A, P=0.8 W,  en=0.0 Wh, F=50.0 Hz, PF=0.10
[18:35:55][D][sensor:092]: 'masterpower_Voltage': Sending state 223.30000 V with 1 decimals of accuracy
[18:35:55][D][sensor:092]: 'masterpower_Current': Sending state 0.03500 A with 3 decimals of accuracy
[18:35:55][D][sensor:092]: 'masterpower_Power': Sending state 0.80000 W with 1 decimals of accuracy
[18:35:55][D][sensor:092]: 'masterpower_Energy': Sending state 0.00200 KwH with 1 decimals of accuracy
[18:35:55][D][sensor:092]: 'masterpower_Frequency': Sending state 50.00000 Hz with 1 decimals of accuracy
[18:35:55][D][sensor:092]: 'masterpower_PowerFactor': Sending state 0.10000  with 2 decimals of accuracy
[18:36:55][D][pzemac:049]: PZEM AC: V=223.2 V, I=0.035 A, P=0.8 W,  en=0.0 Wh, F=50.0 Hz, PF=0.10
[18:36:55][D][sensor:092]: 'masterpower_Voltage': Sending state 223.20000 V with 1 decimals of accuracy
[18:36:55][D][sensor:092]: 'masterpower_Current': Sending state 0.03500 A with 3 decimals of accuracy
[18:36:55][D][sensor:092]: 'masterpower_Power': Sending state 0.80000 W with 1 decimals of accuracy
[18:36:55][D][sensor:092]: 'masterpower_Energy': Sending state 0.00200 KwH with 1 decimals of accuracy
[18:36:55][D][sensor:092]: 'masterpower_Frequency': Sending state 50.00000 Hz with 1 decimals of accuracy
[18:36:55][D][sensor:092]: 'masterpower_PowerFactor': Sending state 0.10000  with 2 decimals of accuracy
[18:37:55][D][pzemac:049]: PZEM AC: V=223.3 V, I=0.035 A, P=0.8 W,  en=0.0 Wh, F=49.9 Hz, PF=0.10
[18:37:55][D][sensor:092]: 'masterpower_Voltage': Sending state 223.30000 V with 1 decimals of accuracy
[18:37:55][D][sensor:092]: 'masterpower_Current': Sending state 0.03500 A with 3 decimals of accuracy
[18:37:55][D][sensor:092]: 'masterpower_Power': Sending state 0.80000 W with 1 decimals of accuracy
[18:37:55][D][sensor:092]: 'masterpower_Energy': Sending state 0.00200 KwH with 1 decimals of accuracy
[18:37:55][D][sensor:092]: 'masterpower_Frequency': Sending state 49.90000 Hz with 1 decimals of accuracy
[18:37:55][D][sensor:092]: 'masterpower_PowerFactor': Sending state 0.10000  with 2 decimals of accuracy
[18:38:55][D][pzemac:049]: PZEM AC: V=223.4 V, I=0.035 A, P=0.8 W,  en=0.0 Wh, F=49.9 Hz, PF=0.10
[18:38:55][D][sensor:092]: 'masterpower_Voltage': Sending state 223.39999 V with 1 decimals of accuracy
[18:38:55][D][sensor:092]: 'masterpower_Current': Sending state 0.03500 A with 3 decimals of accuracy
[18:38:55][D][sensor:092]: 'masterpower_Power': Sending state 0.80000 W with 1 decimals of accuracy
[18:38:55][D][sensor:092]: 'masterpower_Energy': Sending state 0.00200 KwH with 1 decimals of accuracy
[18:38:55][D][sensor:092]: 'masterpower_Frequency': Sending state 49.90000 Hz with 1 decimals of accuracy
[18:38:55][D][sensor:092]: 'masterpower_PowerFactor': Sending state 0.10000  with 2 decimals of accuracy
咦,之前怎么也不行,刚重新刷新就出来了。。。
但上面的警告和错误还在的
qzl
发表于 2021-8-3 08:44:34 | 显示全部楼层
学习学习
发表于 2021-9-4 22:03:20 | 显示全部楼层
学习学习
发表于 2021-9-15 10:16:10 | 显示全部楼层
66666666666666
发表于 2021-9-18 19:59:09 | 显示全部楼层
学习一下
发表于 2021-10-3 19:05:41 | 显示全部楼层
研究研究
发表于 2021-10-4 09:55:38 | 显示全部楼层
學習學習
发表于 2021-10-9 23:19:27 | 显示全部楼层
右胆大包天圧
发表于 2021-10-9 23:36:33 | 显示全部楼层
学习了 感谢分享
发表于 2021-10-10 01:46:52 | 显示全部楼层
过来学习,感谢分享
GMT+8, 2026-1-16 12:57 , Processed in 0.720795 second(s), 11 queries , MemCached On.
