查看: 18213|回复: 19
[已解决] 插排TC1无法接入MQTT
发表于 2019-9-24 20:42:01 | 显示全部楼层 |阅读模式
已经解决了,需要答案的看12楼
这边用树莓派安装了homeassistant,版本0.99.2
根据zTC1的教程(https://github.com/a2633063/zTC1),已经刷了固件,也使用了激活码,用手机app的udp方式能实现控制。
已经在configuration.yaml文件中增加以下代码:
mqtt:
switch:
  - platform: mqtt
    state_topic: 'homeassistant/switch/MAC/plug_0/state'
    command_topic: 'device/ztc1/set'
    payload_on: '{"mac":"MAC","plug_0":{"on":1}}'
    payload_off: '{"mac":"MAC","plug_0":{"on":0}}'
  - platform: mqtt
    state_topic: 'homeassistant/switch/MAC/plug_1/state'
    payload_on: '{"mac":"MAC","plug_1":{"on":1}}'
    payload_off: '{"mac":"MAC","plug_1":{"on":0}}'
  - platform: mqtt
    state_topic: 'homeassistant/switch/MAC/plug_2/state'
    payload_on: '{"mac":"MAC","plug_2":{"on":1}}'
    payload_off: '{"mac":"MAC","plug_2":{"on":0}}'
  - platform: mqtt
    state_topic: 'homeassistant/switch/MAC/plug_3/state'
    payload_on: '{"mac":"MAC","plug_3":{"on":1}}'
    payload_off: '{"mac":"MAC","plug_3":{"on":0}}'
  - platform: mqtt
    state_topic: 'homeassistant/switch/MAC/plug_4/state'
    payload_on: '{"mac":"MAC","plug_4":{"on":1}}'
    payload_off: '{"mac":"MAC","plug_4":{"on":0}}'
  - platform: mqtt
    state_topic: 'homeassistant/switch/MAC/plug_5/state'
    payload_on: '{"mac":"MAC","plug_5":{"on":1}}'
    payload_off: '{"mac":"MAC","plug_5":{"on":0}}'
  - platform: mqtt
    state_topic: 'homeassistant/sensor/MAC/power/state'
    unit_of_measurement: 'W'
    icon: 'mdi:gauge'
    value_template: '{{ value_json.power }}'
homeassistant:
  customize:
    switch.tc1_1:
      friendly_name: TC1插槽1
    switch.tc1_2:
      friendly_name: TC1插槽2
    switch.tc1_3:
      friendly_name: TC1插槽3
    switch.tc1_4:
      friendly_name: TC1插槽4
    switch.tc1_5:
      friendly_name: TC1插槽5
    switch.tc1_6:
      friendly_name: TC1插槽6
    sensor.tc1_power:
      friendly_name: TC1功率
group:
  tc1:
    view: no
    entities:
      - sensor.tc1_power
      - switch.tc1_1
      - switch.tc1_2
      - switch.tc1_3
      - switch.tc1_4
      - switch.tc1_5
      - switch.tc1_6
现在项接入homeassistant,但是连接不上,没法控制。
请问哪位大佬实现过控制了,告知一下中间缺失了什么环节。。。。
发表于 2019-9-24 20:52:10 | 显示全部楼层
是不是自己得整个mqtt服务啊!那个mac要换成自己设备的mac,
另外,最新ztc1固件1.0版,主题变了,相应的写法也有变化。
发表于 2019-9-24 21:33:37 | 显示全部楼层
手机APP中还要设置 MQTT服务器的地址。
 楼主| 发表于 2019-9-24 21:43:18 | 显示全部楼层
哦,是手机app会把这些数据写入插排内吗?
 楼主| 发表于 2019-9-24 21:54:59 | 显示全部楼层
另外,最新ztc1固件1.0版,主题变了,相应的写 ...
没有,就是在配置文件里加了mqtt代码而已。
MAC地址已经更换为设备的地址了。
发表于 2019-9-24 22:45:40 | 显示全部楼层
app的设置里配置好mqtt服务器后需要在插座控制界面点下右上角的云图标上传下配置。
最新版command_topic里边也有mac了‘’
实在不行下载个MQTT.fx调试一下吧
 楼主| 发表于 2019-9-24 23:10:55 | 显示全部楼层
手机提示连接不上服务器
发表于 2019-9-24 23:30:03 | 显示全部楼层
这个需要部署个MQTT服务器
在把插排接入
 楼主| 发表于 2019-9-24 23:37:54 | 显示全部楼层
现在提示已经连接至mqtt服务器,但是仍旧不能控制。见鬼了。
顺便说一句,给同样问题的小伙伴,如果用内置的mqtt服务器,用户名必须是homeassistant,至少我改为这个后提示连接了,虽然还是不能控制。
 楼主| 发表于 2019-9-24 23:42:26 | 显示全部楼层
日志里提示如下:
Invalid connection from (client @=192.168.xx.xx:xxxx) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
GMT+8, 2025-12-17 06:38 , Processed in 0.225259 second(s), 9 queries , MemCached On.
