楼主: xiaoguaileo
Ubuntu16.04 Server X86架构硬件 安装Hass.io
 火.. [复制链接]
发表于 2019-7-7 17:41:41 | 显示全部楼层
受教了……
发表于 2019-8-7 14:06:51 | 显示全部楼层
感谢教程
发表于 2019-8-19 13:24:25 | 显示全部楼层
root@DESKTOP-CE8QUJ1:~/.homebridge# sudo homebridge
[2019-8-19 13:24:16] There was a problem reading your config.json file.
[2019-8-19 13:24:16] Please try pasting your config.json file here to validate it: http://jsonlint.com
/usr/lib/node_modules/homebridge/lib/server.js:218
    throw err;
SyntaxError: Unexpected token } in JSON at position 604
    at JSON.parse (<anonymous>)
    at Server._loadConfig (/usr/lib/node_modules/homebridge/lib/server.js:212:19)
    at new Server (/usr/lib/node_modules/homebridge/lib/server.js:56:38)
    at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:32:16)
    at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:653:30)
    at Object.Module._extensions..js (module.js:664:10)
    at Module.load (module.js:566:32)
    at tryModuleLoad (module.js:506:12)
    at Function.Module._load (module.js:498:3)
发表于 2019-8-19 13:25:49 | 显示全部楼层
[2019-8-19 13:24:16] There was a problem reading ...
哪里的问题啊 ,求助大佬
发表于 2020-1-7 11:46:33 | 显示全部楼层
谢谢楼主分享教程,没注意楼主的日期,按步骤安装到curl发现报错,软件源添加换新的,安装好curl。用curl安装 https://raw.githubusercontent.co ... tall/hassio_install,一直报错,然后点了这个链接发现,链接已经失效了(笑哭)(笑哭)。
楼主,有最新的安装教程么,unbuntu的或者其他发行版本linux。
发表于 2020-10-19 21:06:21 | 显示全部楼层
我打算明天给我的笔电安装 ubuntukylin desktop
发表于 2023-3-21 15:37:40 | 显示全部楼层
GMT+8, 2026-1-14 06:16 , Processed in 1.124768 second(s), 17 queries , MemCached On.
