楼主: xiaoguaileo
Ubuntu16.04 Server X86架构硬件 安装Hass.io
 火.. [复制链接]
发表于 2018-1-21 15:34:13 | 显示全部楼层
好像最后一条命令之前漏一条
sudo apt-get install libavahi-compat-libdnssd-dev
发表于 2018-1-21 16:40:51 | 显示全部楼层
发表于 2018-1-25 22:16:02 | 显示全部楼层
发表于 2018-1-28 12:18:26 | 显示全部楼层
gzroc 发表于 2017-12-18 22:17
鬼鬼啊!你帖有两三个坑啊!新手会给你搞死的。。。
是啊
增加CA证书
sudo apt-get install apt-transport-https ca-certificates
执行这一步 把好多基础包都给卸载了
haha@haha-desktop sudo apt-get install apt-transport-https ca-certificates
Reading package lists... Done
Building dependency tree
Reading state information... Done
ca-certificates is already the newest version (20170717).
The following packages will be REMOVED:
  apt apt-utils ubuntu-desktop ubuntu-minimal ubuntu-release-upgrader-gtk unattended-upgrades update-manager update-notifier update-notifier-common
The following NEW packages will be installed:
  apt-transport-https
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
  apt
0 upgraded, 1 newly installed, 9 to remove and 0 not upgraded.
Need to get 26.1 kB of archives.
After this operation, 7,674 kB disk space will be freed.
You are about to do something potentially harmful.
To continue type in the phrase 'Yes, do as I say!'
?] Yes, do as I say!
Get:1 http://mirrors.aliyun.com/ubuntu xenial-updates/main amd64 apt-transport-https amd64 1.2.24 [26.1 kB]
Fetched 26.1 kB in 0s (209 kB/s)
(Reading database ... 180730 files and directories currently installed.)
Removing ubuntu-minimal (1.404.1) ...
Removing unattended-upgrades (0.98ubuntu1.1) ...
Removing apt-utils (1.5.1) ...
Removing ubuntu-desktop (1.404.1) ...
Removing update-notifier (3.186) ...
Removing update-notifier-common (3.186) ...
Removing apt (1.5.1) ...
Removing update-manager (1:17.10.11) ...
Removing ubuntu-release-upgrader-gtk (1:17.10.8) ...
Selecting previously unselected package apt-transport-https.
(Reading database ... 180217 files and directories currently installed.)
Preparing to unpack .../apt-transport-https_1.2.24_amd64.deb ...
Unpacking apt-transport-https (1.2.24) ...
Setting up apt-transport-https (1.2.24) ...
Processing triggers for gconf2 (3.2.6-4ubuntu1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu3) ...
Processing triggers for libglib2.0-0:amd64 (2.54.1-1ubuntu1) ...
Processing triggers for libc-bin (2.26-0ubuntu2.1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Processing triggers for gnome-menus (3.13.3-6ubuntu5) ...
Processing triggers for hicolor-icon-theme (0.17-1) ...
haha@haha-desktop
haha@haha-desktop sudo apt-key adv --keyserver hkp://p80.pool.sks-keyservers.net:80 --recv-keys 58118E89F3A912897C070ADBF76221572C52609D
sudo: apt-key: command not found
haha@haha-desktop sudo apt-get install apt-key
sudo: apt-get: command not found
发表于 2018-1-30 10:57:43 | 显示全部楼层
请问楼上各位,用这个方法安装的hassio,一段时间以后会有访问不了的情况吗
发表于 2018-1-30 17:01:51 | 显示全部楼层
lidicn 发表于 2017-11-11 16:35
少了一个依赖
sudo apt-get install avahi-utils
是的   我也是装到最后才发现
发表于 2018-1-30 21:01:43 | 显示全部楼层
国际惯例,用一个Hello world的来测试安装成功
sudo docker run hello-world
这里这个坑该如何处理?
error pulling image configuration: Get https://dseasb33srnrn.cloudfront ... 116c9caaab6a2/data?
发表于 2018-1-31 12:10:26 | 显示全部楼层
安装完进入网页,怎么一直是一个图标然后
Preparing Hass.io
(this can take up to 20 minutes)
等了2个小时了都 还是这样?需要怎么做?
发表于 2018-1-31 12:29:16 | 显示全部楼层
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
注意,选中 'libcurl4-openssl-dev' 而非 'libcurl3-dev'
E: 无法定位软件包 php7.0-curl
E: 无法按照 glob ‘php7.0-curl’ 找到任何软件包
E: 无法按照正则表达式 php7.0-curl 找到任何软件包
发表于 2018-2-9 16:36:53 | 显示全部楼层
看样子英特电脑棒可以按照这个教程来弄是吧??
GMT+8, 2025-12-15 23:57 , Processed in 0.248005 second(s), 12 queries , MemCached On.
