楼主: 废柴工程师
[已解决] 我也想用上hassio可是实力不允许啊
 楼主| 发表于 2019-9-7 15:44:02 | 显示全部楼层
lunare 发表于 2019-9-7 15:36
删了最后我的配置文件也没那行
# Configure a default setup of Home Assistant (frontend, api, etc)
defa ...
删除configuration.yaml文件的第13行和第14行重启以后恢复正常
不过这位大大你的这个文件跟我的不一样
 楼主| 发表于 2019-9-7 15:47:04 | 显示全部楼层
lunare 发表于 2019-9-7 15:31
customize: !include customize.yaml
这行删了 好像我昨天重新安装了0.98.4
也是因为这个 ...
我用的是这位恩山坛友的配置文件,图片带连接
 楼主| 发表于 2019-9-7 15:48:34 | 显示全部楼层
# Customization file
这两行自定义文件夹自定义文件?????
发表于 2019-9-7 15:58:29 | 显示全部楼层
0.97的时候这行东西是正常的
更新到0.98的时候就报错了
发表于 2019-9-7 15:58:44 | 显示全部楼层
最后两行有问题吧
 楼主| 发表于 2019-9-7 16:02:20 | 显示全部楼层
余歌唱晚 发表于 2019-9-7 15:58
最后两行有问题吧
log里面提示这一段有问题customize: !include customize.yaml,删除以后可以访问了,您指最下面的也有问题吗?
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 34.0494
  longitude: -118.2641
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: imperial
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: America/Los_Angeles
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
homeassistant:
发表于 2019-9-8 01:39:30 | 显示全部楼层
废柴工程师 发表于 2019-9-7 16:02
log里面提示这一段有问题customize: !include customize.yaml,删除以后可以访问了,您指最下面的也有问 ...
你出现了两个homeassistant: 是不对的  packages 应该是和name等最上面一部分对齐的
发表于 2019-9-8 01:41:23 | 显示全部楼层
homeassistant:
  latitude: 34.0494
  elevation: 0
introduction:
frontend:
config:
# http:
updater:
discovery:
conversation:
history:
logbook:
map:
# Track the sun
sun:
  - platform: yr
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
 楼主| 发表于 2019-9-8 08:10:54 | 显示全部楼层
谢谢您帮我修改,昨天晚上我又搞了好久,路由器劫持成功了,但是DC1还是在HA里面控制不了,不知道跟这里有没有关系
 楼主| 发表于 2019-9-8 09:16:04 | 显示全部楼层
GMT+8, 2025-12-23 22:37 , Processed in 0.073244 second(s), 7 queries , MemCached On.
