查看: 20556|回复: 20
[已解决] 我也想用上hassio可是实力不允许啊
发表于 2019-9-7 14:57:34 | 显示全部楼层 |阅读模式
看来我真的很笨拙 之前也刷过HASSBIAN匹配DC1,老版本的4.18的时候,可能瞎猫碰死耗子给成功了。看到现在的一代又一代的版本修复WIFI修复蓝牙等等,所以刷了新版本,但是问题来了为什么HASSBIAN主界面登陆不了了?后面是我遇到的问题,希望大大给解答一下吧
使用的这个版本+低占用的DTD,点击图片可直接跳转
用的neroxps版主大大一键脚本安装的
curl -sL -o install.sh https://raw.githubusercontent.com/neroxps/hassio_install/master/install.sh
chmod a+x install.sh
./install.sh
接着就是使用的WinSCP上传DC1配置文件+ configuration.yaml文件,DC1配置文件(phicomm_dc1m.py + phicomm_dc1m.yaml),三个文件直接丢到/ TMP目录下。然后腻子执行
mkdir /usr/share/hassio/homeassistant/custom_components
mkdir /usr/share/hassio/homeassistant/custom_components/switch
mkdir /usr/share/hassio/homeassistant/packages
cd /tmp
cp -r phicomm_dc1m.py /usr/share/hassio/homeassistant/custom_components/switch
cp -r phicomm_dc1m.yaml /usr/share/hassio/homeassistant/packages
cp -r configuration.yaml /usr/share/hassio/homeassistant
执行完以后HASSBIAN主界面就打不开了,但是地址可以ping通
下面是我使用的配置文件是哪里不对吗?我感觉是configuration.yaml文件的问题
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 34.0494
  longitude: -118.2641
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: imperial
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: America/Los_Angeles
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
homeassistant:
N1配置DC1.zip
5.44 KB, 下载次数: 3
 楼主| 发表于 2019-9-7 14:59:19 | 显示全部楼层
007.png 主界面网址打不开WinSCP可以正常访问传送文件
发表于 2019-9-7 15:12:35 | 显示全部楼层
你把DC1的phicomm_dc1m.yaml
packages这个目录下的先删除了重启试试
发表于 2019-9-7 15:14:46 | 显示全部楼层
最重要的 home-assistant.log 不发上来~
hassio 说 这锅我不背
 楼主| 发表于 2019-9-7 15:21:59 | 显示全部楼层
DC1配置存放的这两个目录文件夹packages+switch已删除,没有得到解决,还是打不开
 楼主| 发表于 2019-9-7 15:25:58 | 显示全部楼层
hassio 说 这锅我不背
首先感谢版主大大的回复,和我预想的差不多
补上home-assistant.log 文件
2019-09-07 14:18:03 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml:   in "/config/configuration.yaml", line 14, column 14: Unable to read file /config/customize.yaml.
 楼主| 发表于 2019-9-7 15:31:07 | 显示全部楼层
hassio 说 这锅我不背
已解决
参与人数 1金钱 +10 收起 理由
neroxps + 10 自行解决问题以示鼓励
发表于 2019-9-7 15:31:39 | 显示全部楼层
这行删了 好像我昨天重新安装了0.98.4
也是因为这个
 楼主| 发表于 2019-9-7 15:35:40 | 显示全部楼层
也是因为这个 ...
刚刚删了等待重启中,谢谢你的解答
发表于 2019-9-7 15:36:36 | 显示全部楼层
删了最后我的配置文件也没那行
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# http:
# Text to speech
tts:
  - platform: baidu
    app_id: xxx
    api_key: xxx
    secret_key: xxx
    speed: 5
    pitch: 5
    volume: 5
    person: 4
#基础配置
homeassistant:
  customize_glob:
      custom_ui_state_card: state-card-custom-ui
  latitude: xxx
  longitude: xxx
  elevation: 10
  unit_system: metric
  time_zone: Asia/Shanghai
GMT+8, 2025-12-23 22:37 , Processed in 0.262086 second(s), 14 queries , MemCached On.
