楼主: netwolf
[进阶教程] ESP32取论坛撸的魅族温湿度传感器数据发送到mqtt服务器
发表于 2019-10-4 02:25:59 | 显示全部楼层
我的貌似就是新版的,刷一下试试
发表于 2019-10-5 16:55:20 | 显示全部楼层
谢谢楼主!!!!!!!!!!!!!!
发表于 2019-10-15 11:01:01 | 显示全部楼层
This actually helped me to solve the problem with continuous reboot.
In Arduino IDE: click Tools, Board, Board Manager.
After the dialog is loaded type ESP32 and look for:
esp32 by Espressif Systems ...
if it is installed
Press Update button (in my case to version 1.0.4)
if it is not installed, I can not see how you got here to find the continuous reboot problem.
But do not worry, just press Install button.
Try this before you go for 160MHz CPU frequency, 40MHz flash, DIO flash mode, PSRAM disabled etc.
not to mention the resistor and capacitor on EN input.
发表于 2019-10-15 11:04:29 | 显示全部楼层
这是外国友人说的,方便的话试一下吧?
发表于 2019-10-22 16:11:10 | 显示全部楼层
这个应该不错,我的魅族可以用了
发表于 2019-11-10 10:28:42 | 显示全部楼层
正需要学习
准备动手
发表于 2019-11-12 11:55:39 | 显示全部楼层
好用不,老板。
发表于 2019-11-21 00:19:46 | 显示全部楼层
学习学习再学习,谢谢谢谢再谢谢!
发表于 2019-11-24 23:09:35 | 显示全部楼层
thx for share
发表于 2019-12-18 14:33:05 | 显示全部楼层
我的刷完也是用不了,有最新版本的吗?刷的时候不报错,刷完找不到无线
GMT+8, 2025-12-17 18:46 , Processed in 2.015983 second(s), 19 queries , MemCached On.
