楼主: spiter
[求助] 请教有没有用戴森的大神?戴森风飒怎么解
发表于 2019-5-15 10:51:37 | 显示全部楼层
spiter 发表于 2019-5-15 10:50
dyson:
  username:
  password: 123456
这个配置你上面有,我看了没啥问题,最好全部的配置都贴一下,然后把重启的时候homeassistant.log也贴一下
 楼主| 发表于 2019-5-15 10:54:44 | 显示全部楼层
natic 发表于 2019-5-15 10:51
这个配置你上面有,我看了没啥问题,最好全部的配置都贴一下,然后把重启的时候homeassistant.log也贴一下 ...
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: xx.803889
  longitude: 123.382778
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 11
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Asia/shanghai
  # Customization file
  customize: !include customize.yaml
frontend:
  javascript_version: auto
  extra_html_url: /local/lovelace.html
lovelace:
sun:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Discover some devices automatically
discovery:
# Sensors
# Text to speech
tts:
  - platform: google_translate
#  Yeelight #
light:
  - platform: yeelight
    devices:
      10.10.10.128:
        transition: 1000
        use_music_mode: true
        save_on_change: true
switch:
  - platform: xiaomi_miio
    host: 10.10.10.115
    token: 1122b746e655c3956d89b525e
    host: 10.10.10.116
    token: qwqc54a567bcf66460054342
    model: zimi.powerstrip.v2
#xiaomi_cooker:
  #name: Xiaomi Rice Cooker
  #host: 10.10.10.107
  #token: fghfgh38c6076a6a052b3e5cf
  #model: chungmi.cooker.normal2
dyson:
  username: [email protected]
  password: 11113
  language: zh-CN
  devices:
    - device_id: 111-xx1-HJA2933A
    - device_ip: 10.10.10.121
group: !include groups.yaml
script: !include scripts.yaml
发表于 2019-5-15 11:35:02 | 显示全部楼层
spiter 发表于 2019-5-15 10:54
homeassistant:
看了一下,也没啥问题,继续找一下homeassistant.log吧
 楼主| 发表于 2019-5-15 11:46:19 | 显示全部楼层
Log Details (ERROR)
Wed May 15 2019 10:59:31 GMT+0800 (中国标准时间)
Setup failed for Dyson: Integration not found.
LOG是这样提示的
 楼主| 发表于 2019-5-15 11:48:00 | 显示全部楼层
Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
还有这个
我理解是没找到驱动或者是其他什么组件
但是配置文件里没说要什么组件
我也下载了一些配置文件到对应的文件夹里也是不行
发表于 2019-5-15 12:02:17 | 显示全部楼层
dyson:
  username:
  password: 123456
看了下好像是这样配置的
fan:
  - platform: dyson
    username:
 楼主| 发表于 2019-5-15 12:58:36 | 显示全部楼层
natic 发表于 2019-5-15 12:02
看了下好像是这样配置的
fan:
  - platform: dyson
这样我好像试过一会我再试试看看,非常感谢
 楼主| 发表于 2019-5-15 13:10:30 | 显示全部楼层
看了下好像是这样配置的
fan:
  - platform: dyson
还是不行
提示Unable to set up component
发表于 2019-5-15 13:29:34 | 显示全部楼层
spiter 发表于 2019-5-15 13:10
还是不行
还发现一个问题  语言换成GB试试,用最原始的配置
发表于 2019-5-15 13:31:22 | 显示全部楼层
还是不行
报错日志可以直接复制过来,详细一点,这样方便看
GMT+8, 2025-12-22 23:17 , Processed in 0.101629 second(s), 7 queries , MemCached On.
