楼主: 三木
[插件集成] [4月1日更新!!]斐讯DC1插座自制固件接入ha
发表于 2019-7-30 20:52:02 | 显示全部楼层
INFO Reading configuration...
Found multiple options, please choose one:
  [1] COM2 (USB 串行设备 (COM2))
  [2] Over The Air (tv.local)
(number): 1
INFO Running:  esptool.py --before default_reset --after hard_reset --chip esp8266 --port COM2 write_flash 0x0 'D:\DC1\config_yaml\build\tv\.pioenvs\tv\firmware.bin'
esptool.py v2.7
Serial port COM2
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: ec:fa:bc:00:2a:9f
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 2MB
Compressed 382512 bytes to 261867...
Wrote 382512 bytes (261867 compressed) at 0x00000000 in 23.3 seconds (effective 131.3 kbit/s)...
File  md5: c7691ce5cc8e0375da77ac160fdd1a98
Flash md5: e7b01bfd01d074e1f33fd18a27d173a1
MD5 of 0xFF is 2938b1ae91c8ba5ca769e6b9a0a77054
A fatal error occurred: MD5 of file does not match data in flash!
发表于 2019-7-31 14:19:24 | 显示全部楼层
直接进入模块的ip就可以控制了吗,还是需要其他的配置
发表于 2019-8-2 09:15:56 | 显示全部楼层
牛逼!后排学习
发表于 2019-8-2 22:10:49 | 显示全部楼层
修改固件配置文件 是在那里改哟
发表于 2019-8-6 21:37:18 | 显示全部楼层
gzh 发表于 2019-4-25 10:22
稳定运行二个星期
麻烦问一下,这个配置文件怎么写的,配置了多个DC1   默认只显示一个。麻烦了
gzh
发表于 2019-8-7 10:10:10 | 显示全部楼层
配置→集成→新集成→esphome→dc1地址即可
发表于 2019-8-9 07:24:14 | 显示全部楼层
特意来支持三木大
发表于 2019-8-9 16:26:25 | 显示全部楼层
这可真他娘的牛逼啊
发表于 2019-8-9 21:35:40 | 显示全部楼层
求助,我用windows的编译包,不行,提示中途遇到问题,
我用linux 下的在线编译环境,提示如下:
Failed config
esphome: [source esphome_config/123.yaml:2]
  platform: ESP8266
  Could not find board 'csm64f02_b'. Valid boards are d1, d1_mini, d1_mini_lite, d1_mini_pro, esp01, esp01_1m, esp07, esp12e, esp210, esp8285, esp_wroom_02, espduino, espectro, espino, espinotee, espresso_lite_v1, espresso_lite_v2, gen4iod, heltec_wifi_kit_8, huzzah, modwifi, nodemcu, nodemcuv2, oak, phoenix_v1, phoenix_v2, sparkfunBlynk, thing, thingdev, wifi_slot, wifiduino, wifinfo, wio_link, wio_node, xinabox_cw01.
  board: csm64f02_b
  esp8266_restore_from_flash: True
  esphome_core_version:
    repository: https://github.com/Samuel-0-0/esphome-core.git
    branch: dc1
  build_path: build\phicomm_dc1
  arduino_version: 2.5.0
  platformio_options:
    platform: https://github.com/Samuel-0-0/platform-espressif8266.git#dc1
发表于 2019-8-12 19:37:19 | 显示全部楼层
各位 大大大大大大佬们请教个小白问题。 这个是通过HomeAssistant连接苹果homekit还是直接可以连接HOMEkit啊
GMT+8, 2026-1-14 14:18 , Processed in 1.513114 second(s), 10 queries , MemCached On.
