楼主: natic
[基础教程] HA 0.89版本 米家空调伴侣配置更新
发表于 2019-4-29 21:35:46 | 显示全部楼层
报错提示这个该怎么办,检查组件是没有问题的呀,求大神
Error while setting up platform xiaomi_miio_airconditioningcompanion
  File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/tasks.py", line 406, in wait_for
    return fut.result()
  File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/futures.py", line 294, in result
    raise self._exception
  File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/tasks.py", line 240, in _step
    result = coro.send(None)
  File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/coroutines.py", line 210, in coro
    res = func(*args, **kw)
  File "/Users/Fugo/.homeassistant/custom_components/climate/xiaomi_miio_airconditioningcompanion.py", line 96, in async_setup_platform
    from miio import AirConditioningCompanion, DeviceException
ImportError: No module named 'miio'
 楼主| 发表于 2019-4-29 21:37:01 | 显示全部楼层
Error while setting up platform xiaomi_miio_air ...
检查一下配置,代码里面哪里有miio,应该是哪里写错了
发表于 2019-5-27 16:59:54 来自手机 | 显示全部楼层
Mark ,稍后更新
发表于 2019-6-14 00:34:35 | 显示全部楼层
Integration xiaomi_miio_airconditioningcompanion not found when trying to verify its climate platform.
请问那里有错误
 楼主| 发表于 2019-6-14 06:48:54 | 显示全部楼层
quyuan 发表于 2019-6-14 00:34
Integration xiaomi_miio_airconditioningcompanion not found when trying to verify its climate platfor ...
看的新的帖子,有HA新版本更新
发表于 2020-2-29 00:08:38 | 显示全部楼层
ptlzx 发表于 2019-3-12 17:34
https://github.com/syssi/xiaomi_ ... ompanion/climate.py重命名为xiaomi_miio_airconditioningcompanio ...
你好!
你的问题最后是怎么解决的?我和你碰到相同的困扰。
我用的是米家空调伴侣2 现在是0.105.5版本,用上面提供的插件,显示设备不可用。
搞了几天都没有搞好。
发表于 2020-5-17 13:42:19 | 显示全部楼层
我还是0.88,打算升级,先mark一下
GMT+8, 2025-12-30 20:33 , Processed in 0.087988 second(s), 12 queries , MemCached On.
