楼主: natic
[基础教程] HA 0.89版本 米家空调伴侣配置更新
发表于 2019-3-12 18:32:36 | 显示全部楼层
linlingzi 发表于 2019-3-12 18:16
4,删除core.entity_registry下面原来的entity,因为platform变了,不删除会占用原有id这个怎么做 ...
这步怎么操作
 楼主| 发表于 2019-3-12 19:58:13 | 显示全部楼层
找到文件里面对应id的那个json,删除保存,重启即可
活跃会员教程狂人
发表于 2019-3-12 21:49:30 | 显示全部楼层
感谢分享。大神速度好快 。
所有过往,皆为序章。
发表于 2019-3-13 09:55:27 | 显示全部楼层
报错信息:Package climate setup failed. Component climate cannot be merged. Expected a dict.
发表于 2019-3-14 21:55:31 | 显示全部楼层
请问hassos里在哪个目录?
 楼主| 发表于 2019-3-14 22:02:43 | 显示全部楼层
limaomao 发表于 2019-3-14 21:55
请问hassos里在哪个目录?
hassio volume目录的homeassistant文件夹里面
发表于 2019-3-18 12:21:41 | 显示全部楼层
求助~我改了之后为什么一直报这个错误呢?
xiaomi_miio_airconditioningcompanion: Error on device update!
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 346, in async_device_update
    await self.async_update()
  File "/home/homeassistant/.homeassistant/custom_components/xiaomi_miio_airconditioningcompanion/climate.py", line 270, in async_update
    ATTR_SWING_MODE: state.swing_mode.name.lower(),
  File "/srv/homeassistant/lib/python3.5/site-packages/miio/airconditioningcompanion.py", line 215, in swing_mode
    return SwingMode(mode)
  File "/usr/lib/python3.5/enum.py", line 241, in __call__
    return cls.__new__(cls, value)
  File "/usr/lib/python3.5/enum.py", line 476, in __new__
    raise ValueError("%r is not a valid %s" % (value, cls.__name__))
ValueError: 7 is not a valid SwingMode
发表于 2019-4-22 19:28:28 | 显示全部楼层
0.91.4,突然又不行了,错误信息如下:
Mon Apr 22 2019 18:59:39 GMT+0800 (CST)
xiaomi_miio_airconditioningcompanion: Error on device update!ValueError: 4 is not a valid FanSpeedDuring handling of the above exception, another exception occurred:Traceback (most recent call last):  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity    await entity.async_device_update(warning=False)  File "/usr/src/app/homeassistant/helpers/entity.py", line 377, in async_device_update    await self.async_update()  File "/config/custom_components/xiaomi_miio_airconditioningcompanion/climate.py", line 271, in async_update    ATTR_FAN_MODE: state.fan_speed.name.lower(),  File "/usr/local/lib/python3.7/site-packages/miio/airconditioningcompanion.py", line 225, in fan_speed    return FanSpeed(speed)  File "/usr/local/lib/python3.7/enum.py", line 310, in __call__    return cls.__new__(cls, value)  File "/usr/local/lib/python3.7/enum.py", line 564, in __new__    raise exc  File "/usr/local/lib/python3.7/enum.py", line 548, in __new__    result = cls._missing_(value)  File "/usr/local/lib/python3.7/enum.py", line 577, in _missing_    raise ValueError("%r is not a valid %s" % (value, cls.__name__))ValueError: 4 is not a valid FanSpeed
 楼主| 发表于 2019-4-22 21:02:23 | 显示全部楼层
Mon Apr 22 2019 18:59:39 GMT+0800 (CST)xiaomi_miio_airconditi ...
这个是版本的问题吧,更新下试试
 楼主| 发表于 2019-4-22 21:12:55 | 显示全部楼层
natic 发表于 2019-4-22 21:02
这个是版本的问题吧,更新下试试
我刚才也更新了HA,没有发现问题
GMT+8, 2025-12-30 18:35 , Processed in 1.448524 second(s), 10 queries , MemCached On.
