查看: 9432|回复: 9
[求助] 求组!安装看docker+homeassitant成功后8123登不进
发表于 2019-3-4 22:23:00 | 显示全部楼层 |阅读模式
使用【六神分享】20分钟无人值守 一键安装Docker+Hassio 支持3B+
https://bbs.hassbian.com/thread-3501-1-1.html
(出处: 『瀚思彼岸』» 智能家居第一站)的帖子安装的docker+homeassitant后第一次可以正常打开ip:8123在homeassitant网页那里改了一个yaml的文件后重启homeassitant服务后开不了
日志显示说docker有问题,本人非常小白,在做毕设,水生火热!!
求助各位大神!!
 楼主| 发表于 2019-3-4 22:24:14 | 显示全部楼层
日志如下
发表于 2019-3-5 08:51:36 | 显示全部楼层
WINSCP连上去 /usr/share/hassio/homeassistant下把configuration.yaml你修改的地方改回去,docker下重启HA
 楼主| 发表于 2019-3-5 14:31:42 | 显示全部楼层
ghostist 发表于 2019-3-5 08:51
WINSCP连上去 /usr/share/hassio/homeassistant下把configuration.yaml你修改的地方改回去,docker下重启HA ...
谢谢大神,按照大神的方法改了yaml的文件,docker也重启了各个服务器,树莓派也重启了,但是8123还是打开不了,现在日志如下
Mar 05 14:25:48 raspberrypi hassio-supervisor[1894]: 19-03-05 06:25:48 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
Mar 05 14:25:48 raspberrypi hassio-supervisor[1894]: 19-03-05 06:25:48 INFO (MainThread) [hassio.discovery] Load 0 messages
Mar 05 14:25:48 raspberrypi hassio-supervisor[1894]: 19-03-05 06:25:48 INFO (MainThread) [__main__] Run Hass.io
Mar 05 14:25:48 raspberrypi hassio-supervisor[1894]: 19-03-05 06:25:48 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
Mar 05 14:25:48 raspberrypi hassio-supervisor[1894]: 19-03-05 06:25:48 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
Mar 05 14:25:48 raspberrypi hassio-supervisor[1894]: 19-03-05 06:25:48 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
Mar 05 14:25:48 raspberrypi hassio-supervisor[1894]: 19-03-05 06:25:48 INFO (MainThread) [hassio.addons] Startup system run 0 add-ons
Mar 05 14:25:48 raspberrypi hassio-supervisor[1894]: 19-03-05 06:25:48 INFO (MainThread) [hassio.addons] Startup services run 0 add-ons
Mar 05 14:25:48 raspberrypi hassio-supervisor[1894]: 19-03-05 06:25:48 INFO (SyncWorker_5) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
Mar 05 14:25:50 raspberrypi hassio-supervisor[1894]: 19-03-05 06:25:50 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.89.0b1
发表于 2019-3-5 15:49:39 | 显示全部楼层
justinmrx123 发表于 2019-3-5 14:31
谢谢大神,按照大神的方法改了yaml的文件,docker也重启了各个服务器,树莓派也重启了,但是8123还是打开 ...
日志没看出啥来  搜了一下  没找到答案
既然你有docker 那重新拉镜像就好了 很快,备份你的config
 楼主| 发表于 2019-3-5 17:43:49 | 显示全部楼层
ghostist 发表于 2019-3-5 15:49
日志没看出啥来  搜了一下  没找到答案
既然你有docker 那重新拉镜像就好了 很快,备份你的config ...
谢谢回复,但是刚刚查看了一下docker的日志好像是Homeassitant的密码不是英文字符出错建立不了服务,请问下大神知道现在可以在哪个文件改吗
发表于 2019-3-5 18:16:46 | 显示全部楼层
justinmrx123 发表于 2019-3-5 17:43
谢谢回复,但是刚刚查看了一下docker的日志好像是Homeassitant的密码不是英文字符出错建立不了服务,请问 ...
configuration.yaml
http:
  api_password: 你的密码
流水无味
灌水之王
发表于 2019-3-5 19:27:25 | 显示全部楼层
反正你新装的  进去把 configuration.yaml 同目录的所有文件删光即可
ang2
发表于 2019-12-18 14:16:28 | 显示全部楼层
太好了
发表于 2019-12-19 01:42:15 来自手机 | 显示全部楼层
好使了没有
GMT+8, 2025-12-23 20:44 , Processed in 0.059907 second(s), 13 queries , MemCached On.
