楼主: killadm
[经验分享] lovelace第三方插件介绍及界面大赛相关问题答疑[2019/4/27]
发表于 2019-2-17 21:00:51 来自手机 | 显示全部楼层
厉害厉害,膜拜了
发表于 2019-2-17 22:09:33 | 显示全部楼层
請問一下K大....
這空氣淨化器的開關變成紅色的..
請問控制的指令是?  在哪邊修改呢?我有在這邊找 找不到可以改的項目
https://github.com/home-assistan ... sources/ha-style.ts
 楼主| 发表于 2019-2-17 22:15:43 | 显示全部楼层
jozhi 发表于 2019-2-17 22:09
請問一下K大....
這空氣淨化器的開關變成紅色的..
請問控制的指令是?  在哪邊修改呢?我有在這邊找 找不到可 ...
是这个主题里的,想用card-modder改的话参考Switches部分
# Main colors
primary-color: '#5294E2'                                                        # Header
accent-color: '#E45E65'                                                         # Accent color
dark-primary-color: 'var(--accent-color)'                                       # Hyperlinks
light-primary-color: 'var(--accent-color)'                                      # Horizontal line in about
# Text colors
primary-text-color: '#FFFFFF'                                                   # Primary text colour, here is referencing dark-primary-color
text-primary-color: '#FFFFFF'                                                   # Primary text colour
secondary-text-color: '#5294E2'                                                 # For secondary titles in more info boxes etc.
disabled-text-color: '#7F848E'                                                  # Disabled text colour
label-badge-border-color: 'green'                                               # Label badge border, just a reference value
# Background colors
primary-background-color: '#383C45'                                             # Settings background
secondary-background-color: '#383C45'                                           # Main card UI background
divider-color: 'rgba(0, 0, 0, .12)'                                             # Divider
# Table rows
table-row-background-color: '#353840'                                           # Table row
table-row-alternative-background-color: '#3E424B'                               # Table row alternative
# Nav Menu
paper-listbox-color: 'var(--primary-color)'                                     # Navigation menu selection hoover
paper-listbox-background-color: '#2E333A'                                       # Navigation menu background
paper-grey-50: 'var(--primary-text-color)'
paper-grey-200: '#414A59'                                                       # Navigation menu selection
# Paper card
paper-card-header-color: 'var(--accent-color)'                                  # Card header text colour
paper-card-background-color: 'rgba(67, 73, 84, 0.5)'                            # Card background colour
paper-dialog-background-color: 'rgba(67, 73, 84, 0.5)'                          # Card dialog background colour
paper-item-icon-color: 'var(--primary-text-color)'                              # Icon color
paper-item-icon-active-color: '#F9C536'                                         # Icon color active
paper-item-icon_-_color: 'green'
paper-item-selected_-_background-color: '#434954'                               # Popup item select
paper-tabs-selection-bar-color: 'green'
# Labels
label-badge-red: '#DF4C1E'                                                      # References the brand colour label badge border
label-badge-text-color: '#FFFFFF'                                               # Now same as label badge border but that's a matter of taste
label-badge-background-color: '#2E333A'                                         # Same, but can also be set to transparent here
# Switches
paper-toggle-button-checked-button-color: 'var(--accent-color)'
paper-toggle-button-checked-bar-color: 'var(--accent-color)'
paper-toggle-button-checked-ink-color: 'var(--accent-color)'
paper-toggle-button-unchecked-button-color: 'var(--disabled-text-color)'
paper-toggle-button-unchecked-bar-color: 'var(--disabled-text-color)'
paper-toggle-button-unchecked-ink-color: 'var(--disabled-text-color)'
# Sliders
paper-slider-knob-color: 'var(--accent-color)'
paper-slider-knob-start-color: 'var(--accent-color)'
paper-slider-pin-color: 'var(--accent-color)'
paper-slider-active-color: 'var(--accent-color)'
paper-slider-container-color: 'linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat'
paper-slider-secondary-color: 'var(--secondary-background-color)'
paper-slider-disabled-active-color: 'var(--disabled-text-color)'
paper-slider-disabled-secondary-color: 'var(--disabled-text-color)'
# Google colors
google-red-500: '#E45E65'
google-green-500: '#39E949'
发表于 2019-2-17 22:45:59 | 显示全部楼层
[code]# Main colors
請教K大   我改成這樣
          paper-toggle-button-checked-button-color: red
          paper-toggle-button-checked-bar-color: red
          paper-toggle-button-checked-ink-color: red
          paper-toggle-button-unchecked-button-color: red
          paper-toggle-button-unchecked-bar-color: red
          paper-toggle-button-unchecked-ink-color: red
顏色還是沒有變@@"
 楼主| 发表于 2019-2-18 08:10:58 | 显示全部楼层
前边加上--
'--paper-toggle-button-checked-button-color': '#E45E65'
发表于 2019-2-18 08:26:51 | 显示全部楼层
killadm 发表于 2019-2-18 08:10
前边加上--
感謝K大....我今晚回去試試看
发表于 2019-2-18 10:01:56 | 显示全部楼层
lz赞 收集了很多例子可以参考学习了 thanks!
活跃会员教程狂人
发表于 2019-2-21 14:35:52 | 显示全部楼层
大佬更新了,上班了可以玩玩了。谢谢。
所有过往,皆为序章。
版主
发表于 2019-2-21 20:24:52 | 显示全部楼层
请问楼主,我在使用tracker-card和磨砂玻璃效果时,遇到个问题,显示如下,即tracker-card两行之间不同的颜色与磨砂背景效果冲突 新建位图图像.jpg
但我看到您的却不存在这个问题,能够分享下怎样调整tracker-card颜色参数?还是要更改theme?
 楼主| 发表于 2019-2-21 22:21:12 | 显示全部楼层
whxciotw 发表于 2019-2-21 20:24
请问楼主,我在使用tracker-card和磨砂玻璃效果时,遇到个问题,显示如下,即tracker-card两行之间不同的颜 ...
应该是在主题里,表格刷新太快开发者工具来不及看,53楼有我用的主题,你试试把。
GMT+8, 2025-9-19 07:05 , Processed in 1.263948 second(s), 12 queries , MemCached On.
