楼主: carlyang1986
[求助] 求助绿米空调伴侣升级版的网关功能如何接入到HA
 楼主| 发表于 2018-12-1 11:26:27 | 显示全部楼层
coolbug111 发表于 2018-11-23 21:05
网关接入不需要插件,空调伴侣才用
2018-11-18 18:51:11 WARNING (MainThread) [homeassistant.loader] You are using a custom component for xiaomi_aqara which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-11-18 18:51:11 ERROR (MainThread) [homeassistant.setup] Error during setup of component xiaomi_aqara
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/setup.py", line 148, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
AttributeError: module 'custom_components.xiaomi_aqara' has no attribute 'setup'
2018-11-18 18:51:11 WARNING (MainThread) [homeassistant.loader] You are using a custom component for climate.xiaomi_miio which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-11-18 18:51:11 WARNING (MainThread) [homeassistant.loader] You are using a custom component for molohub which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
这段代码我看不懂,好像是有个组件没安装成功。
发表于 2018-12-1 15:27:01 | 显示全部楼层
key一行应该是大写
 楼主| 发表于 2018-12-2 01:44:43 | 显示全部楼层
花蟋蟀 发表于 2018-12-1 15:27
key一行应该是大写
File: /home/homeassistant/.homeassistant/configuration.yaml    Modified
    File: /home/homeassistant/.homeassistant/home-assistant.log              2018-12-01 13:24:58 WARNING (MainThread) [homeassistant.loader] You are usin$2018-12-01 13:25:00 WARNING (MainThread) [homeassistant.loader] You are usin$$g job: Task exception was never retrieved
  File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step                 result = coro.throw(exc)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/setup.py", line$    return await task  # type: ignore
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__            yield self  # This tells Task to wait for completion.                      File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup               future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step                 result = coro.send(None)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/setup.py", line$    component = loader.get_component(hass, domain)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/loader.py", lin$    module = importlib.import_module(path)
  File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 986, in _gcd_import               File "<frozen importlib._bootstrap>", line 969, in _find_and_load
  File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked   File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 669, in exec_module      File "<frozen importlib._bootstrap_external>", line 775, in get_code
  File "<frozen importlib._bootstrap_external>", line 735, in source_to_code   File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_remov$^G Get Help    ^O Write Out   ^W Where Is    ^K Cut Text    ^J Justify
^X Exit        ^R Read File   ^\ Replace     ^U Uncut Text  ^T To Spell
发表于 2018-12-2 11:22:08 | 显示全部楼层
    File: /home/homeassi ...
https://github.com/syssi/xiaomi_airconditioningcompanion
按这个更新一下插件
发表于 2018-12-9 21:01:20 | 显示全部楼层
key是网关的局域网通信密码,如果网关一直没有连接成功,建议你再次查看局域网通信密码是否正确。
 楼主| 发表于 2018-12-15 11:55:26 来自手机 | 显示全部楼层
coolbug111 发表于 2018-11-19 00:38
[code]xiaomi_aqara:
  discovery_retry: 5
  interface: 'HA IP'
您能给我一个compond_custom文件下的xiaomi_aqara配置文件吗?可能我没你的配置文件,所以用不了。方便的话能否发我邮箱[email protected] 万分感谢!
发表于 2018-12-15 13:53:41 | 显示全部楼层
carlyang1986 发表于 2018-12-15 11:55
您能给我一个compond_custom文件下的xiaomi_aqara配置文件吗?可能我没你的配置文件,所以用不了。方便的 ...
网关没有配置文件,空调伴侣才需要
 楼主| 发表于 2018-12-15 16:19:19 | 显示全部楼层
coolbug111 发表于 2018-12-15 13:53
网关没有配置文件,空调伴侣才需要
请问你的HA什么版本,我的就是找不到,郁闷了。
 楼主| 发表于 2018-12-15 17:12:23 | 显示全部楼层
aotelansi 发表于 2018-11-21 22:03
我的没加'  但是在ha界面什么也没显示 实体也没有
请问你绿米空调伴侣的网关功能添加上了吗?我这个log也找不到提示,页面里啥也看不到。
 楼主| 发表于 2018-12-16 01:30:56 | 显示全部楼层
按这个更新一下插件
更新了没啥用,issue里面讨论这个空调伴侣的问题是2.0协议虽然给了key但是9898端口没打开,现在看来是没戏,不知道以后能有什么好办法。
GMT+8, 2025-12-25 08:07 , Processed in 0.285065 second(s), 8 queries , MemCached On.
