楼主: carlyang1986
[求助] 求助绿米空调伴侣升级版的网关功能如何接入到HA
 楼主| 发表于 2018-11-21 13:21:41 来自手机 | 显示全部楼层
coolbug111 发表于 2018-11-19 00:38
[code]xiaomi_aqara:
  discovery_retry: 5
  interface: 'HA IP'
麻烦您帮我看一下这段写的对不对,我在HA的检查里没问题,但是仍然没办法接入进来。第一个ip是我的HA在路由器里面的地址,第二个地址是空调伴侣在路由器里的地址。key和mac我也确认过。我现在的HA版本是0.82.1
 楼主| 发表于 2018-11-21 21:39:28 | 显示全部楼层
[code]xiaomi_aqara:
  discovery_retry: 5
  interface: 'HA IP'
能告诉我你的绿米网关的版本么?是V1还是V3?
发表于 2018-11-21 22:03:28 | 显示全部楼层
我的没加'  但是在ha界面什么也没显示 实体也没有
发表于 2018-11-21 22:22:04 | 显示全部楼层
我是这么写的,你写configuration中要加上 xiaomi_aqara:
 楼主| 发表于 2018-11-22 08:30:40 | 显示全部楼层
# aqara gateway
xiaomi_aqara:
  discovery_retry: 5
  interface: '192.168.2.124'
  gateways:
    - mac: 7C49EB7FD832
      key: 8ks9nc3xencmcxdu
      host: 192.168.2.64
我感觉是我的硬件不支持,有点麻烦。
发表于 2018-11-22 15:07:09 | 显示全部楼层
V3的 我这样配置没问题,可以接入网关和空调
 楼主| 发表于 2018-11-23 11:07:11 来自手机 | 显示全部楼层
我周末回家再弄一次,可能是我有一个xiaomi_aqara.py文件弄的。
发表于 2018-11-23 21:05:07 | 显示全部楼层
网关接入不需要插件,空调伴侣才用
zmg 手机认证
发表于 2018-11-27 17:15:29 | 显示全部楼层
carlyang1986 发表于 2018-11-22 08:30
[code]# aqara gateway
xiaomi_aqara:
  discovery_retry: 5
我有V1、V2各一个,网关功能都连不上,9898端口未打开
 楼主| 发表于 2018-12-1 11:23:20 | 显示全部楼层
2018-11-18 18:51:11 WARNING (MainThread) [homeassistant.loader] You are using a custom component for xiaomi_aqara which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-11-18 18:51:11 ERROR (MainThread) [homeassistant.setup] Error during setup of component xiaomi_aqara
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/setup.py", line 148, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
AttributeError: module 'custom_components.xiaomi_aqara' has no attribute 'setup'
2018-11-18 18:51:11 WARNING (MainThread) [homeassistant.loader] You are using a custom component for climate.xiaomi_miio which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-11-18 18:51:11 WARNING (MainThread) [homeassistant.loader] You are using a custom component for molohub which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
这是我更新的一段log,看样子目前homeasstant还没办法正确的配置网关,可能需要等以后再看吧。
GMT+8, 2025-12-25 08:00 , Processed in 0.370534 second(s), 11 queries , MemCached On.
