楼主: feversky
[进阶教程] 天猫精灵网关, oAuth2认证, 无需额外搭建服务器
发表于 2019-6-17 22:07:04 | 显示全部楼层
expire_hours意思是多少个小时后需要重新进行授权。
设置成0可以永久授权吗?
发表于 2019-7-21 03:22:20 | 显示全部楼层
你好,我想反应一个问题,来论坛不久,只是会一些基础设置,通过您的教程,我已经把自己的天猫精灵接入了HA,但是我在使用的时候发现一个问题想向您反应一下。先说一下的配置环境,我是X86主机安装EXSI虚拟了一个HASS OS来安装的HA,版本为0.95.4,家里老式空调较多,就购买了能接入HA的空调伴侣,在使用了Syssi大神的空调伴侣插件后,您的天猫精灵插件可以打开空调,调整温度,但无法调整风速/风向及关闭空调,我对于Python不是很熟悉,就大致看了一下,觉得是因为S大的空调伴侣插件使用的关机服务命令跟您的插件命令不匹配造成的,但是我并不知道该怎么修改,希望您能修改。感谢您的付出与帮助,谢谢
发表于 2019-8-9 01:06:39 | 显示全部楼层
同一位置的2个传感器应该怎么设置??
发表于 2019-8-10 11:13:05 | 显示全部楼层
LZ 按着做得 但是提示这个错误是怎么回事啊?
2019-08-10 11:07:42 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/app/homeassistant/components/http/real_ip.py", line 37, in real_ip_middleware
  File "/usr/src/app/homeassistant/components/http/ban.py", line 69, in ban_middleware
  File "/usr/src/app/homeassistant/components/http/auth.py", line 228, in auth_middleware
  File "/usr/src/app/homeassistant/components/http/view.py", line 124, in handle
    result = await result
  File "/usr/src/app/homeassistant/components/http/data_validator.py", line 47, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/app/homeassistant/components/http/ban.py", line 80, in handle_req
    resp = await func(view, request, *args, **kwargs)
  File "/usr/src/app/homeassistant/components/auth/login_flow.py", line 166, in post
    request.app["hass"], data["client_id"], data["redirect_uri"]
  File "/usr/src/app/homeassistant/components/auth/indieauth.py", line 35, in verify_redirect_uri
    redirect_uris = await fetch_redirect_uris(hass, client_id)
  File "/usr/src/app/homeassistant/components/auth/indieauth.py", line 77, in fetch_redirect_uris
    parser.feed(data.decode())
UnicodeDecodeError: 'utf-8' codec can't decode bytes in position 1022-1023: unexpected end of data
 楼主| 发表于 2019-8-10 19:14:09 | 显示全部楼层
请检查下https或者http是否设置正确
枸杞泡咖啡,我只要喝一杯~~~
发表于 2019-8-14 14:44:35 | 显示全部楼层
感谢分享!值得学习!
发表于 2019-8-20 16:07:52 | 显示全部楼层
很感谢楼主的鼎力分享,目前在配置过程中遇到一个问题。
按照说明配置的网址都准确的。但是到真机测试这一步,只显示这个界面,也没有让我登录HA。这是什么问题呢?
发表于 2019-8-20 16:59:37 | 显示全部楼层
感谢分享,简单了好多
发表于 2019-8-23 14:42:34 | 显示全部楼层
每次重启HA就要重新授权  这个有好办法破吗?
发表于 2019-8-28 18:51:24 | 显示全部楼层
正在用 Home Assistant Local 登录。
Error: invalid client id or redirect uri
GMT+8, 2025-12-24 04:35 , Processed in 0.367783 second(s), 13 queries , MemCached On.
