楼主: feversky
[进阶教程] 天猫精灵网关, oAuth2认证, 无需额外搭建服务器
发表于 2019-1-24 21:00:02 | 显示全部楼层
同楼上 Oauth token返回不正确. 求大神解惑
 楼主| 发表于 2019-1-24 22:05:33 | 显示全部楼层
大家如果有问题,请仔细阅读帖子,关于如何反馈问题。不过我最近很忙,如果有空的话,会看一下。
枸杞泡咖啡,我只要喝一杯~~~
发表于 2019-1-28 17:55:18 | 显示全部楼层
同样的错误,Oauth token 返回错误
 楼主| 发表于 2019-1-28 21:43:19 | 显示全部楼层
chj18888 发表于 2019-1-24 13:20
按照帖子弄的出现错误~求帮助
给我看看你的服务配置
枸杞泡咖啡,我只要喝一杯~~~
发表于 2019-2-1 00:39:12 | 显示全部楼层
Error during setup of component aligenie
  File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
    hass, processed_config)
  File "/config/custom_components/aligenie.py", line 86, in async_setup
    _places  = json.loads(urlopen('https://open.bot.tmall.com/oauth/api/placelist').read().decode('utf-8'))['data']
  File "/usr/local/lib/python3.6/urllib/request.py", line 223, in urlopen
    return opener.open(url, data, timeout)
  File "/usr/local/lib/python3.6/urllib/request.py", line 532, in open
    response = meth(req, response)
  File "/usr/local/lib/python3.6/urllib/request.py", line 642, in http_response
    'http', request, response, code, msg, hdrs)
  File "/usr/local/lib/python3.6/urllib/request.py", line 564, in error
    result = self._call_chain(*args)
  File "/usr/local/lib/python3.6/urllib/request.py", line 504, in _call_chain
    result = func(*args)
  File "/usr/local/lib/python3.6/urllib/request.py", line 756, in http_error_302
    return self.parent.open(new, timeout=req.timeout)
  File "/usr/local/lib/python3.6/urllib/request.py", line 746, in http_error_302
    self.inf_msg + msg, headers, fp)
urllib.error.HTTPError: HTTP Error 302: The HTTP server returned a redirect error that would lead to an infinite loop.
The last 30x error message was:
发表于 2019-2-2 15:32:58 | 显示全部楼层
想请教楼主传感器的customize.yaml应该怎么写?我的天猫精灵发现不了传感器设备sensor.xiaomi_ap_aqi:
  friendly_name: '卧室空气质量'
  hagenie_deviceType: sensor
  hagenie_zone: 卧室
发表于 2019-2-14 10:10:50 | 显示全部楼层
必须赞大神,不经过论坛确实反应快很多了,,,经测试,不用https也能控制哦!
发表于 2019-2-15 10:13:47 | 显示全部楼层
感谢大神~,请问测试的时候老是返回oauth token返回不正确,可能是什么原因?
发表于 2019-2-16 12:35:48 | 显示全部楼层
大神你好,我在配置后已经成功通过Oauth授权了,可是无法发现设备,log内也没有请求的日志,只有一条2019-02-16 12:12:55 INFO (MainThread) [custom_components.aligenie] Access token expiration: 8760 hours
2019-02-16 12:12:25 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
  File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof
  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:841)
2019-02-16 12:12:25 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
  File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received
  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
以上是接着Hagenie的报错信息,貌似是SSL,错误,可是我的SSL,配置正常,访问好像并没有什么问题呀?是什么原因没办法发现设备呢
发表于 2019-3-7 15:52:36 | 显示全部楼层
楼主你好,我用上了这个 很方便只要自己自定义配置写好 设备全自动刷到猫精里面了,不装ssl证书也能用,但是我遇到的问题是几乎每天都要重新获取一次token  token是不是24小时就失效了啊!!请问有什么办法没有?
GMT+8, 2025-12-24 08:30 , Processed in 0.157321 second(s), 11 queries , MemCached On.
