楼主: feversky
[进阶教程] 天猫精灵网关, oAuth2认证, 无需额外搭建服务器
发表于 2018-11-16 23:33:25 | 显示全部楼层
楼主 我的网络是移动的 ,拨号后的IP还是局域网IP  是不是适用这个教程啊?
发表于 2018-11-17 10:26:54 | 显示全部楼层
2018-11-18 11:37:06 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/data/data/com.termux/files/usr/lib/python3.7/site-packages/homeassistant/setup.py", line 56, in async_setup_component
    return await task  # type: ignore
  File "/data/data/com.termux/files/usr/lib/python3.7/site-packages/homeassistant/setup.py", line 103, in _async_setup_component
    component = loader.get_component(hass, domain)
  File "/data/data/com.termux/files/usr/lib/python3.7/site-packages/homeassistant/loader.py", line 92, in get_component
    module = importlib.import_module(path)
  File "/data/data/com.termux/files/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 724, in exec_module
  File "<frozen importlib._bootstrap_external>", line 860, in get_code
  File "<frozen importlib._bootstrap_external>", line 791, in source_to_code
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/data/data/com.termux/files/home/.homeassistant/custom_components/aligenie.py", line 7
    <!DOCTYPE html>
SyntaxError: invalid syntax
  File "/data/data/com.termux/files/usr/lib/python3.7/site-packages/homeassistant/components/discovery.py", line 7
    <!DOCTYPE html>
发表于 2018-11-17 23:47:05 | 显示全部楼层
Data does not match schema: required key not provided @ data['redirect_uri'] 为啥呀大佬
 楼主| 发表于 2018-11-19 20:07:26 | 显示全部楼层
riyue0000 发表于 2018-11-17 10:26
2018-11-18 11:37:06 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was neve ...
醉了,你得下载.py脚本文件,不是另存为HTML
枸杞泡咖啡,我只要喝一杯~~~
 楼主| 发表于 2018-11-19 20:08:38 | 显示全部楼层
太短了,日志截取长一点
枸杞泡咖啡,我只要喝一杯~~~
发表于 2018-11-19 20:18:37 | 显示全部楼层
我是下载了py啊  放到/data/data/com.termux/files/home/.homeassistant/custom_components/aligenie.py
我用的是Android手机 加  termux
发表于 2018-11-20 02:39:52 | 显示全部楼层
新手请教 个人服务器的登录页面   是不是需要搭建 PHP+MYSQL
 楼主| 发表于 2018-11-21 19:44:42 | 显示全部楼层
riyue0000 发表于 2018-11-19 20:18
我是下载了py啊  放到/data/data/com.termux/files/home/.homeassistant/custom_components/aligenie.py  ...
打开py脚本,看看里面的内容
枸杞泡咖啡,我只要喝一杯~~~
 楼主| 发表于 2018-11-21 19:45:57 | 显示全部楼层
不需要,按照帖子里面的做就可以了
枸杞泡咖啡,我只要喝一杯~~~
发表于 2018-11-22 04:24:31 | 显示全部楼层
显示的设备也是只有天猫精灵官方的设备…………怎么回事?
GMT+8, 2025-12-24 08:24 , Processed in 0.265901 second(s), 8 queries , MemCached On.
