楼主: cnk700i
[插件集成] 通用型定时器【任务列表+周期任务+可服务调用】
发表于 2019-10-6 17:19:27 | 显示全部楼层
感谢提供,正需要
发表于 2019-10-6 17:22:34 | 显示全部楼层
感谢楼主分享
发表于 2019-10-11 22:20:03 | 显示全部楼层
HA更新到0.100.1出錯了.....2019-10-11 21:03:12 ERROR (MainThread) [homeassistant.config] Package timer setup failed. Integration common_timer cannot import name 'run_coroutine_threadsafe' from 'homeassistant.util.async_' (/usr/src/homeassistant/homeassistant/util/async_.py) (See /config/packages/timer.yaml:1).
发表于 2019-10-15 16:03:49 | 显示全部楼层
大赞,支持!!!!!!!
发表于 2019-10-21 16:46:45 | 显示全部楼层
HA更新0.100.2也使用了您最新适配0.100.2的Home Assistant通用定时器插件,但为何 请选择设备类型却是空的(light switch.....等等类型都没显示)    2019-10-21 16:31:02 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/core.py", line 1211, in async_call
    processed_data = handler.schema(service_data)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
    raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: string value is None @ data['options'][3]
发表于 2019-10-22 18:26:58 | 显示全部楼层
秀的起飞了,
发表于 2019-10-23 14:28:26 | 显示全部楼层
这么屌,尔等是我学习的楷模。
发表于 2019-10-24 15:45:56 | 显示全部楼层
小白来学习一下
发表于 2019-10-31 00:57:53 | 显示全部楼层
感谢阖家团圆几天
发表于 2019-10-31 01:06:15 | 显示全部楼层
测试看看
GMT+8, 2026-1-16 07:36 , Processed in 1.568267 second(s), 11 queries , MemCached On.
