楼主: lidicn
斐讯N1刷armbian server3.14内核连接wifi安装Hassio
发表于 2018-7-1 09:36:48 来自手机 | 显示全部楼层
gkq1877 发表于 2018-7-1 01:31
Log viewer settings
Auto-refresh logs
Display timestamps
手动pull aarch64-homeassistant:0.71.0试下?
发表于 2018-7-2 02:53:49 | 显示全部楼层
具体怎么操作  PTTYU直接命令pull aarch64-homeassistant:0.71.0吗?
发表于 2018-7-2 11:59:42 | 显示全部楼层
唯独N1只有8G,我现在已经免U盘启动了。。勉强装下DOCKER ,hassio。。。
发表于 2018-7-2 15:10:56 | 显示全部楼层
不用U盘引导了 有具体方法吗?
czde
发表于 2018-7-3 11:34:11 | 显示全部楼层
大哥。现在是0.72.0了
发表于 2018-7-8 11:08:42 | 显示全部楼层
8-07-08 03:05:42 INFO (MainThread) [hassio.homeassistant] No HomeAssistant docker homeassistant/-homeassistant:0.73.0 found.
18-07-08 03:05:42 INFO (MainThread) [hassio.homeassistant] Setup HomeAssistant landingpage
18-07-08 03:05:42 INFO (SyncWorker_0) [hassio.docker.interface] Pull image homeassistant/-homeassistant:0.73.0 tag landingpage.
18-07-08 03:05:42 ERROR (SyncWorker_0) [hassio.docker.interface] Can't install homeassistant/-homeassistant:0.73.0:landingpage -> 400 Client Error: Bad Request ("invalid reference format").
18-07-08 03:05:42 WARNING (MainThread) [hassio.homeassistant] Fails install landingpage, retry after 60sec
18-07-08 03:06:42 INFO (SyncWorker_4) [hassio.docker.interface] Pull image homeassistant/-homeassistant:0.73.0 tag landingpage.
18-07-08 03:06:42 ERROR (SyncWorker_4) [hassio.docker.interface] Can't install homeassistant/-homeassistant:0.73.0:landingpage -> 400 Client Error: Bad Request ("invalid reference format").
18-07-08 03:06:42 WARNING (MainThread) [hassio.homeassistant] Fails install landingpage, retry after 60sec
18-07-08 03:07:42 INFO (SyncWorker_5) [hassio.docker.interface] Pull image homeassistant/-homeassistant:0.73.0 tag landingpage.
18-07-08 03:07:43 ERROR (SyncWorker_5) [hassio.docker.interface] Can't install homeassistant/-homeassistant:0.73.0:landingpage -> 400 Client Error: Bad Request ("invalid reference format").
18-07-08 03:07:43 WARNING (MainThread) [hassio.homeassistant] Fails install landingpage, retry after 60sec
这个怎么回事???
发表于 2018-7-8 22:47:11 | 显示全部楼层
thruway 发表于 2018-7-2 15:10
不用U盘引导了 有具体方法吗?
恩山上有,只是内置空间稍微小一点,应该可以把空间调大一点的。
发表于 2018-7-30 15:24:06 | 显示全部楼层
4.16 核心的能驱动蓝牙吗?
教程狂人论坛风云人物突出贡献
 楼主| 发表于 2018-7-30 23:41:16 | 显示全部楼层
goldstep 发表于 2018-7-30 15:24
4.16 核心的能驱动蓝牙吗?
不能,所以我又刷了3.x
发表于 2018-7-31 01:07:03 | 显示全部楼层
lidicn 发表于 2018-7-30 23:41
不能,所以我又刷了3.x
3.x下的蓝牙貌似也没啥用, 能驱动,但是做tts 卡的要命
GMT+8, 2025-12-29 19:55 , Processed in 1.037397 second(s), 11 queries , MemCached On.
