楼主: jyz_0501
[基础教程] 【六神分享】Raspbian无人值守 一键安装Docker+Hassio 支持3B+
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-4-21 20:12:27 | 显示全部楼层
stoger 发表于 2018-4-21 20:11
不行呀哥,这一个多小时,安装过程中会偶尔提哦出要我按Q退出,或者按Y OR N 的,我都按了让他继续的,我 ...
不能啊,我这好好的啊,我所有的安装命令都是加了 -y 自动的,
请问你是树莓派吗??  还有我用的putty
发表于 2018-4-21 20:13:30 | 显示全部楼层
请问你是树莓派吗??  还有我用的putty  ...
嗯嗯,我是B3,也是用的putty来操作的,
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-4-21 20:15:30 | 显示全部楼层
那不对啊,我用我卡刷了不下3遍了~~没问题啊~
发表于 2018-4-21 20:17:33 | 显示全部楼层
那我等下再刷刷看,我刚才已经不作死就不会死的把刚装好的系统给搞残废了
发表于 2018-4-21 21:23:28 | 显示全部楼层
我又重装了一遍,确实会跳出 按Q 退出,不按就不能继续
et:121 http://mirrors.aliyun.com/raspbian/raspbian/ stretch/main scim-im-agent armhf 1.4.17-1 [59.4 kB]
Get:122 http://mirrors.aliyun.com/raspbian/raspbian/ stretch/main scim-gtk-immodule armhf 1.4.17-1 [44.4 kB]
Get:123 http://mirrors.aliyun.com/raspbian/raspbian/ stretch/main scim-pinyin armhf 0.5.92-3+b1 [1,633 kB]
Fetched 185 MB in 1min 29s (2,070 kB/s)
Reading changelogs... Done
  This can be changed by setting the apt configuration option
    "Binary::apt::APT::Keep-Downloaded-Packages" to "true". E.g:
  # echo 'Binary::apt::APT::Keep-Downloaded-Packages "true";' \
      > /etc/apt/apt.conf.d/01keep-debs
  Please note that the behavior of apt-get is unchanged. The
  downloaded debs will be kept in the cache directory after they
  are installed. To enable the behavior for other tools, you can set
  "APT::Keep-Downloaded-Packages" to false.
  [ Compressed indices ]
  If you use Acquire::gzipIndexes, or any other compressed index targets,
  those will now be compressed with the fastest supported algorithm,
  currently lz4.
-- Michael Vogt <[email protected]>  Tue, 05 Jan 2016 19:22:16 +0100
apt (1.1~exp9) experimental; urgency=medium
  A new algorithm for pinning has been implemented, it now assigns a
  pin priority to a version instead of assigning a pin to a package.
  This might break existing corner cases of pinning, if they use multiple
  pins involving the same package name or patterns matching the same
  package name, but should overall lead to pinning that actually works
  as intended and documented.
-- Julian Andres Klode <[email protected]>  Mon, 17 Aug 2015 14:45:17 +0200
glibc (2.21-2) unstable; urgency=medium
  Starting with version 2.21-1, the glibc requires a 3.2 or later Linux
  kernel.  If you use an older kernel, please upgrade it *before*
  installing this glibc version. Failing to do so will end-up with the
  following failure:
    Preparing to unpack .../libc6_2.21-1_amd64.deb ...
    Checking for services that may need to be restarted...
    Checking init scripts...
    WARNING: this version of the GNU libc requires kernel version
    3.2 or later. Please upgrade your kernel before installing
    glibc.
  Note: This obviously does not apply to non-Linux kernels.
-- Aurelien Jarno <[email protected]>  Thu, 03 Dec 2015 22:46:21 +0100
(q to quit)
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-4-21 22:37:45 | 显示全部楼层
et:121 http://mirrors.aliyun.com/raspbian/raspb ...
我也重新刷了下,没问题啊  我是官方的Raspbian 刷的 从头到尾 都是全自动啊~
发表于 2018-4-22 00:48:09 | 显示全部楼层
折腾了大半天,终于找到原因了,原来是使用的树莓派系统镜像的版本问题,我一直用的是jessie版本,而不是现在官网最新的stretch,现在换了这个最新版本,执行安装脚本后,确实只要大半个小时就全部弄好了,谢谢大神你的这个教程,让我终于从各种盲升级成为了 小白
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-4-22 12:49:41 | 显示全部楼层
stoger 发表于 2018-4-22 00:48
折腾了大半天,终于找到原因了,原来是使用的树莓派系统镜像的版本问题,我一直用的是jessie版本,而不是现 ...
哦 版本冲突一直提示你 源有问题 ,解决了就好~~看来我也该提醒下适配版本问题
发表于 2018-4-23 18:30:06 | 显示全部楼层
楼主,照你的做完后安装好了   可是登录Homeassi要密码 不知道是多少 能告诉一下吗?或者知道一下找密码的方法
发表于 2018-4-24 14:42:13 | 显示全部楼层
先谢谢大神。小弟初用linux
但是我这边出现了些许问题,请指教。
系统是树莓派3B 2017-09-07-raspbian-stretch-lite
开始apt-get的步骤出现了一个错误,404 not found。是否是源的问题
然后去到需要输入yes的地方,还是进不去docker
GMT+8, 2025-6-29 12:10 , Processed in 1.802202 second(s), 26 queries .
