楼主: jyz_0501
[基础教程] 【六神分享】Raspbian无人值守 一键安装Docker+Hassio 支持3B+
发表于 2018-4-21 14:12:17 | 显示全部楼层
能不能帮忙看下我这问题在哪
下面是HB的日志
[2018-4-21 14:07:04] [HomeAssistant] Received event: {"event_type": "state_changed", "data": {"entity_id": "sensor.processor_use", "old_state": {"entity_id": "sensor.processor_use", "state": "2", "attributes": {"unit_of_measurement": "%", "friendly_name": "Processor use", "icon": "mdi:memory"}, "last_changed": "2018-04-21T06:06:33.379334+00:00", "last_updated": "2018-04-21T06:06:33.379334+00:00"}, "new_state": {"entity_id": "sensor.processor_use", "state": "1", "attributes": {"unit_of_measurement": "%", "friendly_name": "Processor use", "icon": "mdi:memory"}, "last_changed": "2018-04-21T06:07:04.375451+00:00", "last_updated": "2018-04-21T06:07:04.375451+00:00"}}, "origin": "LOCAL", "time_fired": "2018-04-21T06:07:04.375622+00:00"}
[2018-4-21 14:07:04] [HomeAssistant] Received event: {"event_type": "state_changed", "data": {"entity_id": "sensor.memory_use_percent", "old_state": {"entity_id": "sensor.memory_use_percent", "state": "26.9", "attributes": {"unit_of_measurement": "%", "friendly_name": "Memory use (percent)", "icon": "mdi:memory"}, "last_changed": "2018-04-21T06:06:02.377093+00:00", "last_updated": "2018-04-21T06:06:02.377093+00:00"}, "new_state": {"entity_id": "sensor.memory_use_percent", "state": "27.0", "attributes": {"unit_of_measurement": "%", "friendly_name": "Memory use (percent)", "icon": "mdi:memory"}, "last_changed": "2018-04-21T06:07:04.393711+00:00", "last_updated": "2018-04-21T06:07:04.393711+00:00"}}, "origin": "LOCAL", "time_fired": "2018-04-21T06:07:04.393925+00:00"}
[2018-4-21 14:07:09] [HomeAssistant] Received event: {"event_type": "state_changed", "data": {"entity_id": "sensor.dark_sky_temperature", "old_state": {"entity_id": "sensor.dark_sky_temperature", "state": "25.2", "attributes": {"attribution": "Powered by Dark Sky", "unit_of_measurement": "\u00b0C", "friendly_name": "Dark Sky Temperature", "icon": "mdi:thermometer"}, "last_changed": "2018-04-21T06:00:56.137116+00:00", "last_updated": "2018-04-21T06:00:56.137116+00:00"}, "new_state": {"entity_id": "sensor.dark_sky_temperature", "state": "25.3", "attributes": {"attribution": "Powered by Dark Sky", "unit_of_measurement": "\u00b0C", "friendly_name": "Dark Sky Temperature", "icon": "mdi:thermometer"}, "last_changed": "2018-04-21T06:07:09.189678+00:00", "last_updated": "2018-04-21T06:07:09.189678+00:00"}}, "origin": "LOCAL", "time_fired": "2018-04-21T06:07:09.189823+00:00"}
Withdrawing address record for 169.254.128.117 on hassio.
Withdrawing address record for 172.30.32.1 on hassio.
Withdrawing address record for fe80::8e54:f3d7:2905:458c on wlan0.
Withdrawing address record for 192.168.2.167 on wlan0.
Host name conflict, retrying with unknown-33
Registering new address record for fe80::7ec8:8757:4c50:1541 on hassio.*.
Registering new address record for 169.254.128.117 on hassio.*.
Registering new address record for 172.30.32.1 on hassio.*.
Registering new address record for fe80::8e54:f3d7:2905:458c on wlan0.*.
Registering new address record for 192.168.2.167 on wlan0.*.
[2018-4-21 14:07:30] [HomeAssistant] Received event: {"event_type": "state_changed", "data": {"entity_id": "sun.sun", "old_state": {"entity_id": "sun.sun", "state": "above_horizon", "attributes": {"next_dawn": "2018-04-21T21:35:28+00:00", "next_dusk": "2018-04-21T11:41:14+00:00", "next_midnight": "2018-04-21T16:38:44+00:00", "next_noon": "2018-04-22T04:38:46+00:00", "next_rising": "2018-04-21T22:01:31+00:00", "next_setting": "2018-04-21T11:15:15+00:00", "elevation": 60.35, "azimuth": 227.53, "friendly_name": "Sun"}, "last_changed": "2018-04-21T06:00:46.575446+00:00", "last_updated": "2018-04-21T06:06:30.373140+00:00"}, "new_state": {"entity_id": "sun.sun", "state": "above_horizon", "attributes": {"next_dawn": "2018-04-21T21:35:28+00:00", "next_dusk": "2018-04-21T11:41:14+00:00", "next_midnight": "2018-04-21T16:38:44+00:00", "next_noon": "2018-04-22T04:38:46+00:00", "next_rising": "2018-04-21T22:01:31+00:00", "next_setting": "2018-04-21T11:15:15+00:00", "elevation": 60.2, "azimuth": 227.92, "friendly_name": "Sun"}, "last_changed": "2018-04-21T06:00:46.575446+00:00", "last_updated": "2018-04-21T06:07:30.372845+00:00"}}, "origin": "LOCAL", "time_fired": "2018-04-21T06:07:30.372989+00:00"}
[2018-4-21 14:07:35] [HomeAssistant] Received event: {"event_type": "state_changed", "data": {"entity_id": "sensor.processor_use", "old_state": {"entity_id": "sensor.processor_use", "state": "1", "attributes": {"unit_of_measurement": "%", "friendly_name": "Processor use", "icon": "mdi:memory"}, "last_changed": "2018-04-21T06:07:04.375451+00:00", "last_updated": "2018-04-21T06:07:04.375451+00:00"}, "new_state": {"entity_id": "sensor.processor_use", "state": "2", "attributes": {"unit_of_measurement": "%", "friendly_name": "Processor use", "icon": "mdi:memory"}, "last_changed": "2018-04-21T06:07:35.376313+00:00", "last_updated": "2018-04-21T06:07:35.376313+00:00"}}, "origin": "LOCAL", "time_fired": "2018-04-21T06:07:35.376484+00:00"}
[2018-4-21 14:07:35] [HomeAssistant] Received event: {"event_type": "state_changed", "data": {"entity_id": "sensor.memory_use_percent", "old_state": {"entity_id": "sensor.memory_use_percent", "state": "27.0", "attributes": {"unit_of_measurement": "%", "friendly_name": "Memory use (percent)", "icon": "mdi:memory"}, "last_changed": "2018-04-21T06:07:04.393711+00:00", "last_updated": "2018-04-21T06:07:04.393711+00:00"}, "new_state": {"entity_id": "sensor.memory_use_percent", "state": "26.9", "attributes": {"unit_of_measurement": "%", "friendly_name": "Memory use (percent)", "icon": "mdi:memory"}, "last_changed": "2018-04-21T06:07:35.394857+00:00", "last_updated": "2018-04-21T06:07:35.394857+00:00"}}, "origin": "LOCAL", "time_fired": "2018-04-21T06:07:35.395061+00:00"}
Host name conflict, retrying with unknown-34
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-4-21 14:13:17 | 显示全部楼层
marshmallow 发表于 2018-4-21 14:12
能不能帮忙看下我这问题在哪
下面是HB的日志
[2018-4-21 14:07:04] [HomeAssistant] Received event: {"eve ...
你这里面没有错误,这是正常的log
错误在时间后面都是Error  或者Warning
发表于 2018-4-21 15:37:30 | 显示全部楼层
非常感谢,树莓派系统安装HA  直接安装HASSBIAN 这两种方法已经折腾好久了,接下来也折腾下这个方法
发表于 2018-4-21 17:14:17 | 显示全部楼层
jyz_0501 发表于 2018-4-21 14:11
请阅读 https://github.com/nfarina/homebridge
Common Issues
My iOS App Can't Find Homebridge
谢谢指点,我装的HB是frenck弄的,在他主页下面没找到这些说明,
再次感谢
发表于 2018-4-21 17:48:25 | 显示全部楼层
按照步骤操作,历时 hassio
  • 已连接: 1小时49分8秒
  • IP地址: 192.168.31.168
  • 终于完成了,感动ing........
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-4-21 18:52:21 | 显示全部楼层
stoger 发表于 2018-4-21 17:48
按照步骤操作,历时 hassio
  • 已连接: 1小时49分8秒
  • 哇 居然这么久吗??我感觉没这么久啊,  你这是连接上的时间吧,不是安装时间吧
    发表于 2018-4-21 19:45:21 | 显示全部楼层
    jyz_0501 发表于 2018-4-21 18:52
    哇 居然这么久吗??我感觉没这么久啊,  你这是连接上的时间吧,不是安装时间吧 ...
    这个是刷好系统,连接上路由就一步一步按照教程操作,一直到成功显示后就登陆路由看的时间,应该是差不多这个时间的  不论怎样,终于是折腾成功了
    我就是六神
    活跃会员教程狂人灌水之王
     楼主| 发表于 2018-4-21 19:58:40 | 显示全部楼层
    stoger 发表于 2018-4-21 19:45
    这个是刷好系统,连接上路由就一步一步按照教程操作,一直到成功显示后就登陆路由看的时间,应该是差不多 ...
    嗯 起码这1个多小时不用管他,让它自动的就好了~~
    发表于 2018-4-21 20:07:14 | 显示全部楼层
    厉害了……简单
    发表于 2018-4-21 20:11:16 | 显示全部楼层
    不行呀哥,这一个多小时,安装过程中会偶尔提哦出要我按Q退出,或者按Y OR N 的,我都按了让他继续的,我不管它会不会自动继续呢?
    GMT+8, 2025-6-29 12:09 , Processed in 1.277725 second(s), 23 queries .
