楼主: 三金
[技术探讨] 国家电网(25.12.8)杂交接入
发表于 2025-12-10 16:40:15 | 显示全部楼层
dscao 发表于 2025-12-9 23:18
我在3个hassos 最新的core中试了一下,
我是2025.3.3的 Core好久没更新过,也一样
发表于 2025-12-10 16:56:47 | 显示全部楼层
有没有办法添加两户的电网?想把老家的电量也加上
 楼主| 发表于 2025-12-10 20:10:43 | 显示全部楼层
可以尝试手动pip安装依赖
发表于 2025-12-10 20:22:18 | 显示全部楼层
我是2025.11.2 能正常安装,你先备份,再升下级试试呢。
发表于 2025-12-10 21:00:23 | 显示全部楼层
大佬你好!我的docker版homeassistant,将文件拷到 custom_components的目录下了,添加集成的时候提示“无法加载配置向导: 500 Internal Server Error Server got itself in trouble”,求指导下。下面是系统日志;日志记录器: aiohttp.server
来源: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:481
首次出现: 20:52:20 (5 次出现)
上次记录: 20:57:30
Error handling request from 42.232.4.248
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 510, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 41, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 83, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 179, in post
    return await self._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 186, in _post_impl
    return await super()._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 83, in _post_impl
    result = await self._flow_mgr.async_init(
    ...<2 lines>...
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1464, in async_init
    flow, result = await self._async_init(flow_id, handler, context, data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1500, in _async_init
    flow = await self.async_create_flow(handler, context=context, data=data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1722, in async_create_flow
    handler = await _async_get_flow_handler(
        self.hass, handler_key, self._hass_config
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3871, in _async_get_flow_handler
    await _load_integration(hass, domain, hass_config)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3848, in _load_integration
    await async_process_deps_reqs(hass, hass_config, integration)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 584, in async_process_deps_reqs
    await requirements.async_get_integration_with_requirements(
        hass, integration.domain
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 54, in async_get_integration_with_requirements
    return await manager.async_get_integration_with_requirements(domain)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 170, in async_get_integration_with_requirements
    await future
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 159, in async_get_integration_with_requirements
    await self._async_process_integration(integration, done)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 182, in _async_process_integration
    await self.async_process_requirements(
        integration.domain, integration.requirements
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 264, in async_process_requirements
    self._raise_for_failed_requirements(name, missing)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 292, in _raise_for_failed_requirements
    raise RequirementsNotFound(integration, [req])
homeassistant.requirements.RequirementsNotFound: Requirements for state_grid not found: ['onnxruntime>=1.17.0'].
发表于 2025-12-12 08:51:43 | 显示全部楼层
学习一下
发表于 2025-12-15 11:40:38 | 显示全部楼层
大佬能不能加个本月预估电费的实体呀
发表于 2025-12-30 11:52:28 | 显示全部楼层
感谢大佬分享,我去试一下....
顺便请问大佬,我看了下github,貌似有什么登陆啊,capcha的代码,那就不用安装ARC-MX大佬的那个docker了吧?
谢谢大佬指点
发表于 2026-1-7 05:28:15 | 显示全部楼层
多帐户有问题? 只加载了2条 后面的不显示了?
有了等了一会就显示全了 感谢
发表于 2026-1-10 08:20:27 | 显示全部楼层
pipx install onnxruntime numpy pillow
  installed package onnxruntime 1.23.2, installed using Python 3.11.2
  These apps are now globally available
    - onnxruntime_test
done! ✨ 🌟 ✨
  installed package numpy 2.4.0, installed using Python 3.11.2
    - f2py
    - numpy-config
done! ✨ 🌟 ✨
No apps associated with package pillow or its dependencies. If you are attempting to install a library,
pipx should not be used. Consider using pip or a similar tool instead.
GMT+8, 2026-1-27 12:51 , Processed in 0.317743 second(s), 11 queries , MemCached On.
