- 积分
- 169
- 金钱
- 161
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 169
- 金钱
- 161
- HASS币
- 0
楼主 |
发表于 2025-8-26 20:57:36
显示全部楼层
系统日志下了100行,不知能否看出端倪
params=list(request_list.values()))
File "/config/custom_components/xiaomi_home/miot/miot_cloud.py", line 727, in get_props_async
res_obj = await self.__mihome_api_post_async(
...<5 lines>...
File "/config/custom_components/xiaomi_home/miot/miot_cloud.py", line 341, in __mihome_api_post_async
http_res = await self._session.post(
...<3 lines>...
timeout=timeout)
File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 770, in _request
resp = await handler(req)
File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 725, in _connect_and_send_request
conn = await self._connector.connect(
req, traces=traces, timeout=real_timeout
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 642, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1209, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1538, in _create_direct_connection
raise ClientConnectorDNSError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorDNSError: Cannot connect to host ha.api.io.mi.com:443 ssl:default [Could not contact DNS servers]
[0m
[31m2025-08-26 20:55:19.365 ERROR (MainThread) [custom_components.xiaomi_home.miot.miot_client] refresh props error, cloud, Cannot connect to host ha.api.io.mi.com:443 ssl:default [Could not contact DNS servers], Traceback (most recent call last):
File "/usr/local/lib/python3.13/site-packages/aiohttp/resolver.py", line 117, in resolve
resp = await self._resolver.getaddrinfo(
...<5 lines>...
aiodns.error.DNSError: (11, 'Could not contact DNS servers')
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1532, in _create_direct_connection
hosts = await self._resolve_host(host, port, traces=traces)
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1148, in _resolve_host
return await asyncio.shield(resolved_host_task)
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1179, in _resolve_host_with_throttle
addrs = await self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.13/site-packages/aiohttp/resolver.py", line 126, in resolve
raise OSError(None, msg) from exc
OSError: [Errno None] Could not contact DNS servers
File "/config/custom_components/xiaomi_home/miot/miot_client.py", line 1634, in __refresh_props_from_cloud
results = await self._http.get_props_async(
...<5 lines>...
...<3 lines>...
timeout=timeout)
[0m
