- 积分
- 339
- 金钱
- 275
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 339
- 金钱
- 275
- HASS币
- 0
楼主 |
发表于 2025-9-19 16:19:01
显示全部楼层
可能跟你本身的不太契合,摘取了主要部分
[{"id":"3334e18484058ca0","type":"function","z":"fd52b829db4a3552","name":"延时计算","func":" const text = String(msg.message.data.message|| \"\"); \n const cps = 4.5; \n // 每秒字数估算 \n const base = 600; \n // 启停缓冲 \n const minMs = 2500; \n // 最短播报时间 \n let ms = Math.round(text.length / cps * 1000) + base; \n if (ms < minMs) ms = minMs; \n msg.delay = ms; \n return msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":310,"y":990,"wires":[["d66a5cdd219267b1"]]},{"id":"d66a5cdd219267b1","type":"delay","z":"fd52b829db4a3552","name":"播报","pauseType":"delayv","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":430,"y":990,"wires":[["069d15b996317937"]]},{"id":"069d15b996317937","type":"api-call-service","z":"fd52b829db4a3552","name":"听取","server":"af60973181b8eb80","version":7,"debugenabled":false,"action":"button.press","floorId":[],"areaId":[],"deviceId":[],"entityId":["button.xiaomi_cn_701352757_lx06_wake_up_a_5_3"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"button","service":"press","x":540,"y":990,"wires":[["2f13941137506015"]]},{"id":"2f13941137506015","type":"ha-wait-until","z":"fd52b829db4a3552","name":"执行","server":"af60973181b8eb80","version":3,"outputs":2,"entities":{"entity":["event.xiaomi_cn_1180420111_hub1_virtual_event_e_4_1"],"substring":[],"regex":[]},"property":"attributes.事件名称","comparator":"includes","value":"\"是的,不是\"","valueType":"jsonata","timeout":"2","timeoutType":"num","timeoutUnits":"minutes","checkCurrentState":true,"blockInputOverrides":true,"outputProperties":[{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":660,"y":990,"wires":[["efc89ecd69c2ee42","7c425b48f1c66231"],["7d18fba5baf41054"]]},{"id":"efc89ecd69c2ee42","type":"function","z":"fd52b829db4a3552","name":"是的","func":"// @ts-nocheck\nif (msg.data.attributes.事件名称 ===\"是的\") {\n return msg;\n} else{\n return null;\n};","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":800,"y":930,"wires":[["0c0418e85a1f9e95"]]},{"id":"7c425b48f1c66231","type":"function","z":"fd52b829db4a3552","name":"不是","func":"// @ts-nocheck\nif (msg.data.attributes.事件名称 ===\"不是\") {\n return msg;\n} else{\n return null;\n};","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":800,"y":980,"wires":[["9b18660b82706d1f"]]},{"id":"7d18fba5baf41054","type":"api-call-service","z":"fd52b829db4a3552","name":"超时不操作通知","server":"af60973181b8eb80","version":7,"debugenabled":false,"action":"notify.send_message","floorId":[],"areaId":[],"deviceId":[],"entityId":["notify.xiaomi_cn_701352757_lx06_play_text_a_5_1"],"labelId":[],"data":"{\"message\":\"超过2分钟没有听到你的回复,那就先不操作吧\",\"title\":\"\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"notify","service":"send_message","x":830,"y":1030,"wires":[[]]},{"id":"af60973181b8eb80","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":true,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
