查看: 1391|回复: 3
[求助] External Components要怎么写?
发表于 2025-2-21 00:32:58 | 显示全部楼层 |阅读模式
ESP home升级到最新版,Custom Components不能用了,需要改成External Components,问了几个AI,都写不对,只有来求助各位大佬了!
实现的功能就是读取UART RX 并设置到text sensor。
之前参考的帖子:
https://bbs.hassbian.com/thread-9794-1-1.html
https://bbs.hassbian.com/thread-23167-1-1.html
组件:
#include "esphome.h"
using namespace esphome;
class MyCustomComponent : public Component, public uart::UARTDevice {
 protected:
  unsigned char telegram[100];
  char data[100];
  bool read_message() {
    int i = 0;
    if (available()) {
      while (available()) {
        telegram[i] = read();
        data[i] = (char) telegram[i];
        ESP_LOGD("DmsrCustom", "0x%x", telegram[i]);
        i++;
      data[i] = 0;
      ESP_LOGD("DmsrCustom", data);
      uart_text_sensors->publish_state(data);
    return false;
 public:
  MyCustomComponent(UARTComponent *parent) : UARTDevice(parent) {}
  TextSensor *uart_text_sensors = new TextSensor();
  void setup() override {
    // nothing to do here
  void loop() override {
    // Use Arduino API to read data, for example
    if (available()) {
      ESP_LOGD("DmsrCustom", "loop start");
      read_message();
jjcs 手机认证
发表于 2025-2-21 09:10:35 | 显示全部楼层
建议不要升级,回退
发表于 2025-2-21 11:07:26 | 显示全部楼层
https://github.com/eigger/espcom ... uartex#state-schema
下载到本地,亲测可用,灰常强大
 楼主| 发表于 2025-2-23 23:17:55 | 显示全部楼层
wencqiang 发表于 2025-2-21 11:07
https://github.com/eigger/espcomponents/tree/master/components/uartex#state-schema
下载到本地,亲测 ...
感谢!这个好像很强大
目前用的https://github.com/tube0013/esphome-stream-server-v2这个,数据全交给nodered处理了
GMT+8, 2025-12-16 14:03 , Processed in 0.395404 second(s), 12 queries , MemCached On.
