查看: 6655|回复: 16
[技术探讨] 智能电表通过rs485走modbus协议接入ha
发表于 2025-2-17 10:05:37 | 显示全部楼层 |阅读模式
ESP8266 MODBUS TCP转RTU
https://bbs.hassbian.com/thread-28615-1-1.html
(出处: 『瀚思彼岸』» 智能家居技术论坛)
结合上一个贴,我们做一个 MODBUS TCP转RTU的设备,
在这里用到3个设备:
1、永诺yn20e智能电表,来自咸鱼10块钱
2、esp01s一个3元
3.ttl转485模块一个2元
yn20e有485接口,支持modbus协议。用esp8266做一个modbus rtu tcp透传设备(源码已经分享)通过modbus tcp 传输到ha。
configuration.yaml代码复制就可以使用
modbus:
  - type: tcp
    host: 192.168.1.15
    port: 502
    sensors:
      - name: "A相电压"
        address: 0x0046
        scale: 0.1
        slave: 2
        precision: 2
        unit_of_measurement: V
        data_type: int16
        unique_id: "2023062821"
        device_class: voltage
      - name: "A相电流"
        address: 0x004C
        slave: 2
        precision: 2
        scale: 0.01
        unit_of_measurement: A
        data_type: int16
        unique_id: "2023062822"
        device_class: current
      - name: "A相有功 功率"
        address: 0x004F
        slave: 2
        precision: 2
        scale: 1
        unit_of_measurement: W
        state_class: total
        data_type: int16
        unique_id: "2023062823"
        device_class: energy
      - name: "A相无功 功率"
        address: 0x0053
        slave: 2
        precision: 2
        scale: 1
        unit_of_measurement: Var
        data_type: int16
        unique_id: "2023062824"
      - name: "A相视功 功率"
        address: 0x0057
        slave: 2
        precision: 2
        scale: 1
        unit_of_measurement: VA
        state_class: total
        data_type: int16
        unique_id: "2023062825"
      - name: "A相功率因素"
        address: 0x005B
        slave: 2
        precision: 2
        scale: 0.001
        unit_of_measurement: F
        data_type: int16
        unique_id: "2023062826"
      - name: "频率"
        address: 0x005F
        slave: 2
        precision: 2
        scale: 0.01
        unit_of_measurement: HZ
        data_type: int16
        unique_id: "2023062827"
      - name: "当前总有功电能"
        address: 0x0063
        slave: 2
        precision: 2
        scale: 0.01
        unit_of_measurement: kWh
        state_class: total
        data_type: int32
        unique_id: "2023062828"
      - name: "当前总有功电能1"
        address: 0x2000
        slave: 2
        precision: 2
        scale: 0.01
        state_class: total
        data_type: int32
        unique_id: "2023062829"
      - name: "波特率"
        address: 0x0211
        slave: 2
        precision: 2
        scale: 1
        data_type: int16
        unique_id: "2023062830"
永诺yn20e电表
永诺yn20e电表
485
485
发表于 2025-2-17 11:33:09 | 显示全部楼层
怎么给8266供电的,外接usb数据线吗
发表于 2025-2-17 12:56:38 | 显示全部楼层
好像使用这种方式接入HA,不是显示为单个设备,而是多个零散的实体,很不爽
 楼主| 发表于 2025-2-17 13:16:45 | 显示全部楼层
sorrypqa 发表于 2025-2-17 12:56
好像使用这种方式接入HA,不是显示为单个设备,而是多个零散的实体,很不爽 ...
是的啊
jjcs 手机认证
发表于 2025-2-17 14:52:28 | 显示全部楼层
为何不在esphome处理,而是透传到ha
 楼主| 发表于 2025-2-17 18:22:38 | 显示全部楼层
web_server:
  port: 80
uart:
  rx_pin: 2
  tx_pin: 0
  baud_rate: 9600
  data_bits: 8
  stop_bits: 1
modbus:
  uart_id: mbus
  send_wait_time: 200ms
modbus_controller:
  - id: modbus_device
    ## the Modbus device addr
    modbus_id: modbus1
    address: 3
    update_interval: 5s
switch:
  - platform: modbus_controller
    modbus_controller_id: modbus_device
    register_type: coil
    address: 0x0000
    register_type: coil
    address: 0x0001
    register_type: coil
    address: 0x0002
binary_sensor:
  register_type: discrete_input
  address: 0x0008
esphome也用了,感觉都不行啊,半个小时或者一个小时才更新一次数据
jjcs 手机认证
发表于 2025-2-17 18:38:42 | 显示全部楼层
不可能把,你透传轮询也是一样的逻辑,只是一个底层处理一个应用层处理
 楼主| 发表于 2025-2-17 19:08:57 | 显示全部楼层
jjcs 发表于 2025-2-17 18:38
不可能把,你透传轮询也是一样的逻辑,只是一个底层处理一个应用层处理 ...
esphome我也用了啊,你看上面的代码
 楼主| 发表于 2025-2-17 19:14:06 | 显示全部楼层
esp怎么连接2个或者三个从站啊,我试了多次都不行
 楼主| 发表于 2025-2-18 13:22:08 | 显示全部楼层
用的电表的3.3v
GMT+8, 2026-1-15 08:30 , Processed in 0.986125 second(s), 6 queries , MemCached On.
