查看: 2409|回复: 2
[经验分享] ha升级到2024.10后Anniversaries集成无法使用的解决办法
发表于 2024-10-9 22:25:10 | 显示全部楼层 |阅读模式
首先关于这个集成不了解的可以看这个帖子,是否有能方便的统计和显示日期倒数或耗材寿命的卡片? - 『HomeAssistant』求助&解答专区 - 『瀚思彼岸』» 智能家居技术论坛 - Powered by Discuz! (hassbian.com) 1.png
ha升级到2024.10后Anniversaries集成无法使用,后面去github找到解决办法,分享给需要的伙伴,只需要进入config\custom_components\anniversaries文件夹内,打开__init__.py文件(记事本打开也可以),将__init__.py文件内的内容全部删除,复制我下面提供的代码,粘贴到__init__.py文件内,保存__init__.py文件,之后整个系统全部重新重启,就可以正常使用了。
"""The Anniversaries Integration"""
import logging
from homeassistant import config_entries
from homeassistant.helpers import discovery
from integrationhelper.const import CC_STARTUP_VERSION
from .const import (
    CONF_SENSORS,
    CONF_DATE_TEMPLATE,
    DOMAIN,
    ISSUE_URL,
    PLATFORM,
    VERSION,
    CONFIG_SCHEMA,
_LOGGER = logging.getLogger(__name__)
async def async_setup(hass, config):
    """Set up this component using YAML."""
    if config.get(DOMAIN) is None:
        # config flow setup
        return True
    # Log startup message
    _LOGGER.info(
        CC_STARTUP_VERSION.format(name=DOMAIN, version=VERSION, issue_link=ISSUE_URL)
    platform_config = config[DOMAIN].get(CONF_SENSORS, {})
    # If platform is not enabled, skip.
    if not platform_config:
        return False
    for entry in platform_config:
        hass.async_create_task(
            discovery.async_load_platform(hass, PLATFORM, DOMAIN, entry, config)
        hass.config_entries.flow.async_init(
            DOMAIN, context={"source": config_entries.SOURCE_IMPORT}, data={}
    return True
async def async_setup_entry(hass, config_entry):
    """Set up this integration using UI."""
    if config_entry.source == config_entries.SOURCE_IMPORT:
        # Set up using YAML
        hass.async_create_task(hass.config_entries.async_remove(config_entry.entry_id))
        return False
    _LOGGER.info(
    # Update config entry options using async_update_entry
    hass.config_entries.async_update_entry(
        config_entry, options=config_entry.data
    # Add update listener
    config_entry.add_update_listener(update_listener)
    # Forward setup to platform (e.g., sensor)
    hass.async_add_job(
        hass.config_entries.async_forward_entry_setup(config_entry, PLATFORM)
    return True
async def async_remove_entry(hass, config_entry):
    """Handle removal of an entry."""
    try:
        await hass.config_entries.async_forward_entry_unload(config_entry, PLATFORM)
        _LOGGER.info(
            "Successfully removed sensor from the Anniversaries integration"
    except ValueError:
        pass
async def update_listener(hass, entry):
    """Update listener."""
    entry.data = entry.options
    await hass.config_entries.async_forward_entry_unload(entry, PLATFORM)
    hass.async_add_job(hass.config_entries.async_forward_entry_setup(entry, PLATFORM))
发表于 2024-10-10 14:15:49 | 显示全部楼层
谢谢分享
发表于 2024-10-24 18:06:52 | 显示全部楼层
问题出在哪里呢?其他集成无法使用的时候,有什么办法处理吗?
GMT+8, 2025-12-23 07:54 , Processed in 0.110762 second(s), 14 queries , MemCached On.
