楼主: Yonsm
[智能音箱] ZhiBot Genie - 天猫精灵一步接入 HomeAssistant,设备零配置
活跃会员教程狂人
发表于 2021-4-12 17:17:09 | 显示全部楼层
wow,大佬更新了,非常感谢。
所有过往,皆为序章。
发表于 2021-4-29 21:50:09 | 显示全部楼层
geniebot.py 会尝试从 HA 配置信息中,根据规则尝试自动转换成天猫精灵匹配的名称和类型。但有些可能匹配不成功,此时可以在 customize.yaml 中,定制天猫精灵能识别的区域、名称和类型,如:
genie_zone: 客厅genie_deviceName: 吸顶灯genie_deviceType: outlet
我的问题如何不让它自动匹配,我的全部switich和light全部转过去了,而有些我是不需要的,能不能需要的按照上述标注,不需要的就不添加标注就不会自动匹配了
我就是六神
活跃会员教程狂人灌水之王
发表于 2021-5-7 02:29:00 | 显示全部楼层
xiaopi 发表于 2021-4-29 21:50
geniebot.py 会尝试从 HA 配置信息中,根据规则尝试自动转换成天猫精灵匹配的名称和类型。但有些可能匹配不 ...
genie_hidden :true. 应该是这个
发表于 2021-5-7 14:11:29 | 显示全部楼层
好用,谢谢
发表于 2021-5-16 23:40:07 | 显示全部楼层
configuration.yaml中添加zhibot后出现如下报错
并且无法创建长效令牌~
https访问也无法正常~
去除zhibot后
访问和长效令牌都正常了
Logger: aiohttp.server
Source: auth/__init__.py:423
First occurred: 下午11:35:03 (1 occurrences)
Last logged: 下午11:35:03
Error handling request
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 129, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 83, in handle_req
    resp = await func(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/auth/__init__.py", line 255, in post
    return await self._async_handle_auth_code(hass, data, request.remote)
  File "/usr/src/homeassistant/homeassistant/components/auth/__init__.py", line 316, in _async_handle_auth_code
    refresh_token = await hass.auth.async_create_refresh_token(
  File "/usr/src/homeassistant/homeassistant/auth/__init__.py", line 423, in async_create_refresh_token
    return await self._store.async_create_refresh_token(
TypeError: async_create_refresh_token() takes from 2 to 7 positional arguments but 8 were given
frx 手机认证
发表于 2021-5-17 11:05:38 | 显示全部楼层
同样遇到楼上的问题。
版本        core-2021.5.4
前端版本: 20210504.0 - latest
天猫技能那边当然也就是返回了:Oauth token 返回不正确,请检查, 3秒后返回设备列表
发表于 2021-5-18 23:17:42 | 显示全部楼层
淘宝App Key徐娅申请吗?怎么申请
发表于 2021-5-19 22:02:31 | 显示全部楼层
并且无法创建长效令牌~
https访问也无法正常~
我的也是这个问题,后来去掉这个插件,创建长效令牌,然后用
zhibot:
  - platform: genie
    token: !secret zhibot_token #增加这行
网关地址改成https://xxx.xxx.xxx:8123//geniebot?token=******
等登录,也能测试,但是就是没有设备导入天猫
发表于 2021-5-19 22:45:06 | 显示全部楼层
发表于 2021-5-21 15:42:38 | 显示全部楼层
zhibot:
  - platform: genie
HA 2021.2.1 就没问题, 升到2021.5.1以后就不行了, 长效令牌创建不了,天猫技能里返回值也出错。
GMT+8, 2025-9-17 02:54 , Processed in 0.171981 second(s), 12 queries , MemCached On.
