楼主: 123xdxd
[技术探讨] 求助!关于zigbee2mqtt设备老是离线不可用
 楼主| 发表于 2024-8-22 20:13:18 | 显示全部楼层
二十四书生 发表于 2024-8-21 18:00
18块的米家通断器慎买,凌动功能不好使,开灯时倒是没问题,响应速度很快,关灯时要开关要断电近半秒,继 ...
我倒是不用凌动功能,一般是实体开关接s1s2直接控制,我家三控开关后面也是硬加了一条线就为了能保证实体开关功能的前提下再加个手机控制。米家这个通断器倒是装过一个给一个射灯用,暂时没发现延迟问题,现在也担心买多个以后再出问题,给你这么一说也不知道该用啥了
发表于 2024-8-26 09:30:14 | 显示全部楼层
123xdxd 发表于 2024-8-22 20:13
我倒是不用凌动功能,一般是实体开关接s1s2直接控制,我家三控开关后面也是硬加了一条线就为了能保证实体 ...
我怀疑是硬件设计问题,开关断开后负载上的电容会给通断器充电导致通断器难以识别到断电信号
如果有单独的S1S2端子接开关的话,这种应该没问题
发表于 2025-5-18 22:09:36 | 显示全部楼层
我这也跟你一样,网关换了一个样,崩溃
{"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE')'
[2025-05-18 21:22:38] error:         z2m: Publish 'get' 'power_on_behavior' to '负二电梯房开关' failed: 'Error: ZCL command 0x60a423fffe93e59f/1 manuSpecificTuya_3.read(["powerOnBehavior"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE')'
[2025-05-18 21:22:39] error:         z2m: Publish 'get' 'backlight_mode' to '负二泡茶区开关' failed: 'Error: ZCL command 0x5c0272fffecbf53e/1 genOnOff.read(["tuyaBacklightSwitch"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE')'
[2025-05-18 21:22:44] error:         z2m: Publish 'get' 'backlight_mode' to '负二电梯房开关' failed: 'Error: ZCL command 0x60a423fffe93e59f/1 genOnOff.read(["tuyaBacklightSwitch"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE')'
[2025-05-18 21:23:02] error:         z2m: Publish 'get' 'power_on_behavior' to '一楼厨房开关' failed: 'Error: ZCL command 0x847127fffe0b6708/1 manuSpecificTuya_3.read(["powerOnBehavior"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE')'
[2025-05-18 21:23:02] error:         z2m: Publish 'get' 'backlight_mode' to '一楼厨房开关' failed: 'Error: ZCL command 0x847127fffe0b6708/1 genOnOff.read(["tuyaBacklightSwitch"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE')'
[2025-05-18 21:23:04] error:         z2m: Publish 'get' 'indicator_mode' to '0xa4c138f4dbac146b' failed: 'Error: ZCL command 0xa4c138f4dbac146b/1 genOnOff.read(["tuyaBacklightMode"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 41622 - 1 - 20 - 6 - 1 after 10000ms)'
[2025-05-18 21:26:06] error:         z2m: Publish 'set' 'state' to '负一书房开关' failed: 'Error: ZCL command 0x0cae5ffffefead6f/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
[2025-05-18 21:38:35] error:         z2m: Publish 'set' 'state' to '负一书房开关' failed: 'Error: ZCL command 0x0cae5ffffefead6f/3 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
[2025-05-18 21:48:41] error:         z2m: Publish 'set' 'state' to '负一书房开关' failed: 'Error: ZCL command 0x0cae5ffffefead6f/2 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225))'
[2025-05-18 22:00:34] error:         z2m: Publish 'get' 'power_on_behavior' to '负二泡茶区开关' failed: 'Error: ZCL command 0x5c0272fffecbf53e/1 manuSpecificTuya_3.read(["powerOnBehavior"],
发表于 2025-5-19 09:17:47 | 显示全部楼层
这个通断器我用过,信号非常非常弱,就是个垃圾。以前我用它做餐灯的控制。在zigbee标准协议里,所有的零火设备都可以做中继器使用的。当时买它是因为我的zigbee网关在客厅,次卧和厨房离网关距离比较远,所以特意买了个这个零火的通断器,期望它能起到中继的作用。结果中继效果不好,它自己还会莫名其妙掉线。
GMT+8, 2026-1-15 18:16 , Processed in 0.812025 second(s), 8 queries , MemCached On.
