查看: 5282|回复: 13
[技术探讨] 求助!关于zigbee2mqtt设备老是离线不可用
发表于 2024-8-20 18:09:15 | 显示全部楼层 |阅读模式
西西买了几个zigbee开关当灯控,用的那种USB的zigbee网关,也怀疑过是信道的问题,z2m里面修改信道15,20,25直接就不能用,只有11才行。几个灯轮流失效,搞得心累
 楼主| 发表于 2024-8-20 18:10:51 | 显示全部楼层
之前还离线一大半,后面点了重新配置才重新在线,在线了也没用,打开开关有几率就失效或者打开以后关闭不了,
z2m: Publish 'set' 'state' to '客厅大灯' failed: 'Error: ZCL command 0xa4c1380ee5e60321/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 52236 - 1 - 147 - 6 - 11 after 10000ms)'
 楼主| 发表于 2024-8-20 18:12:26 | 显示全部楼层
z2m: Failed to configure '餐厅射灯', attempt 1 (Error: ZCL command 0xa4c13899594e2f4f/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 60556 - 1 - 35 - 0 - 1 after 10000ms) at Object.start (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at EZSPAdapter.sendZclFrameToEndpointInternal (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:485:47) at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/app/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:767:28) at Endpoint.read (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:402:29) at Object.configureMagicPacket (/app/node_modules/zigbee-herdsman-converters/src/lib/tuya.ts:430:9) at configure (/app/node_modules/zigbee-herdsman-converters/src/devices/tuya.ts:1437:13) at Object.configure (/app/node_modules/zigbee-herdsman-converters/src/index.ts:190:21) at Configure.configure (/app/lib/extension/configure.ts:126:13))
发表于 2024-8-21 08:19:54 | 显示全部楼层
1 换个zigbee网关试一下
2 换其他zigbee模块试一下
无非就是信号问题,看一下到底是网关的信号不行,还是模块的信号不行,z2m升级到最新版自制的ZigBee灯控,用了2年了,没出现过不能控制和离线的情况
WIFI电表,ZigBee电表 单相 三相
 楼主| 发表于 2024-8-21 09:37:47 | 显示全部楼层
zxl_hass 发表于 2024-8-21 08:19
1 换个zigbee网关试一下
2 换其他zigbee模块试一下
无非就是信号问题,看一下到底是网关的信号不行,还是模 ...
只能这样排除了,不过为啥切换信道插件就启动不了,在yaml里面修改信道也不行
发表于 2024-8-21 12:23:19 | 显示全部楼层
123xdxd 发表于 2024-8-21 09:37
只能这样排除了,不过为啥切换信道插件就启动不了,在yaml里面修改信道也不行 ...
更改zigbee信道后,需要删除zigbee2mqtt目录下的coordinator_backup.json,所有的“已入网”设备还需要重新配网。
发表于 2024-8-21 14:11:02 | 显示全部楼层
是不是网关断电重启过,我的同款通断器就是这样,断电后无线自动重连
 楼主| 发表于 2024-8-21 16:11:02 | 显示全部楼层
你这么一说好像还真是,上次破壁机坏了插上以后跳闸,恢复以后就这样,挺不稳的,还好就装了七个这样的设备还没全屋都上,再不行都准备上米家了,我看米家类似这款的通断器才18,zigbee这个一个26左右。
 楼主| 发表于 2024-8-21 16:30:18 | 显示全部楼层
Roger 发表于 2024-8-21 12:23
更改zigbee信道后,需要删除zigbee2mqtt目录下的coordinator_backup.json,所有的“已入网”设备还需要重 ...
感谢指点,难怪怎么修改都不行,我去试试
发表于 2024-8-21 18:00:07 | 显示全部楼层
123xdxd 发表于 2024-8-21 16:11
你这么一说好像还真是,上次破壁机坏了插上以后跳闸,恢复以后就这样,挺不稳的,还好就装了七个这样的设 ...
18块的米家通断器慎买,凌动功能不好使,开灯时倒是没问题,响应速度很快,关灯时要开关要断电近半秒,继电器才会关掉。
不过有个可能的远因是我带的负载是LED,有一个通断器控制白炽灯这种阻性负载,似乎没有这个问题
GMT+8, 2026-1-15 19:47 , Processed in 0.400208 second(s), 14 queries , MemCached On.
