楼主: 冬瓜HA
冬瓜HAOS通刷魔百盒S905L3A方案教程 os16.3.1
发表于 2024-12-6 09:19:40 | 显示全部楼层
感谢大佬无私奉献,原本装修期间想要达到all in one集合在HA的功能,后因为自己折腾docker内装HA非完全版等一系列问题搁置了很久,偶然发现这个非常不错,昨晚尝试刷机,整个过程也比较简洁,但是还是有些疑惑,还想请解惑解惑。
就是我按照顺序刷完,homeassistant.local:8124    wghatools.local:7681这几个地址打不开,用IP+ha的端口能打开,不知是怎么回事。另外,刷机过程中我没有中断新建用户,而是新建用户了,这个有什么影响吗?
谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢!
 楼主| 发表于 2024-12-6 12:01:14 | 显示全部楼层
wangzian2006 发表于 2024-12-6 09:19
感谢大佬无私奉献,原本装修期间想要达到all in one集合在HA的功能,后因为自己折腾docker内装HA非完全版等 ...
进入后的命令行,用homeassistant.lcoal:7681
发表于 2024-12-6 13:18:18 | 显示全部楼层
homeassistant.lcoal:7681  这个也无法打开,是什么原因呢
发表于 2024-12-6 14:45:11 | 显示全部楼层
http://homeassistant.local:7681/
这个地址,冬瓜大佬 写错了
发表于 2024-12-6 17:06:42 | 显示全部楼层
有没有大佬碰到过8123进不去的
4357 7681都正常能进去,网络肯定没有问题
终端也没有报错,直接就进入到了cli界面
发表于 2024-12-6 17:29:38 | 显示全部楼层
接上面,图片太大发不出来。home-assistant容器没起来
docker logs有报错
root@homeassistant:/var/log # docker logs homeassistant
unconfined
services-up: info: copying legacy longrun home-assistant (no readiness notification)
2024-12-06 17:15:37.833 ERROR (MainThread) [root] Uncaught exception
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
    exit_code = runner.run(runtime_conf)
  File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run
    return loop.run_until_complete(setup_and_run_hass(runtime_config))
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 687, in run_until_complete
    return future.result()
  File "/usr/src/homeassistant/homeassistant/runner.py", line 157, in setup_and_run_hass
    hass = await bootstrap.async_setup_hass(runtime_config)
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 311, in async_setup_hass
    await hass.async_add_executor_job(conf_util.process_ha_config_upgrade, hass)
  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/config.py", line 549, in process_ha_config_upgrade
    if version_obj < AwesomeVersion("0.50"):
  File "/usr/local/lib/python3.12/site-packages/awesomeversion/awesomeversion.py", line 156, in __lt__
    raise AwesomeVersionCompareException(
awesomeversion.exceptions.AwesomeVersionCompareException: Can't compare <unknown > and <SimpleVer 0.50>
[09:15:39] INFO: Home Assistant Core finish process exit code 1
[09:15:39] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
发表于 2024-12-6 17:37:13 | 显示全部楼层
fenny96 发表于 2024-12-6 17:06
有没有大佬碰到过8123进不去的
终端也没有报错,直接就进入到了c ...
新刷完机
第一次启动,系统会下载core镜像(core镜像不预装,因为太大,官方就是这么设计的)
core镜像下载有550MB左右
由于国内docker的网速限制
镜像下载会比较慢,特别是现在晚上17-22点,下载的人员太多。
建议你耐心等(可能需要20-120分钟不等)
或者换其他时间段,一般10分钟内能完成core镜像下载
你可以通过进入7681
输入login进入命令行界面,ha-install -t命令看进度
或者进入8124冬瓜伴侣界面(需要最新13.2.1版,特别是amlogic的方案必须是bigfs版本)
查看docker下载进度
发表于 2024-12-16 15:29:29 | 显示全部楼层
老大您好~ 我按照你得流程 也提示我成功了,断开电源拔下U盘  在开启,ip在路由里就没有了,怎么也登录不上了,这样该如何解决啊~谢谢
v1na 手机认证
发表于 2024-12-16 15:43:23 | 显示全部楼层
kdjcl 发表于 2024-12-16 15:29
老大您好~ 我按照你得流程 也提示我成功了,断开电源拔下U盘  在开启,ip在路由里就没有了,怎么也登录不上 ...
检查一下选择dtb那一步是不是正确选择了dtb
发表于 2024-12-16 18:48:12 | 显示全部楼层
e900c22d 写入失败有大佬说dtb改成m401a后写入成功了
wghatools login: root
Password:
Login incorrect
Password:
    _              _   ____  ___   ___  ____  _ _____
   / \   _ __ ___ | | / ___|/ _ \ / _ \| ___|| |___ /  __ _
  / _ \ | '_ ` _ \| | \___ \ (_) | | | |___ \| | |_ \ / _` |
/ ___ \| | | | | | |_ ___) \__, | |_| |___) | |___) | (_| |
/_/   \_\_| |_| |_|_(_)____/  /_/ \___/|____/|_|____/ \__,_|
Welcome to Armbian OS 24.5.0 Jammy with Linux 6.1.32-ophub
System load:   12%              Up time:       4 min    Local users:   2
Memory usage:  8% of 1.90G      IP:            192.168.94.97
CPU temp:      43°C             Usage of /:    14% of 14G
storage/:      29% of 510M
RX today:      37.1 KiB
Last login: Fri Apr 19 23:49:25 CST 2024 on tty1
root@wghatools:~# ./zwgusb2haos_s905l3a
Please select language number: (1: 中文/2: English) 请10秒内输入对应语言编号(1:中文/2: 英文):
                          WaxGroud HAOS s905l3a 系列安装工具 V1.2
                                         警告
                                     刷机有风险,操作需谨慎
                                    请确保已经备份了重要数据
本HAOS已经测试过以下的机型,其他机型欢迎测试反馈:
CM311-1a-YST
M401A
UNT403A
E900V22D
B863AV3.2-M
IP112H
你确定要运行吗?(确定y/取消n)
y
引导设备 : mmcblk2boot0
来源设备 : sda1
目标设备 : mmcblk2
厂商编号 : 0x000015
OEM 编号 : 0x0100
OEM 名称 : 8GTF4R
OEM 日期 : 12/2021
OEM 序号 : 0x0f9d5872
已用寿命 : 0 - 10%
=>自动选择了 u-boot.20240121.bin
选择冬瓜haos系统镜像文件:
1 - haos_s905l3a_bigfs_cn-13.2.1.release.20241130_143341.4a4e7574c7
=>自动选择了 haos_s905l3a_bigfs_cn-13.2.1.release.20241130_143341.4a4e7574c7.img.xz
解锁emmc的引导分区中.
解锁emmc的引导分区完成.
开始写入uboot.bin
=>写模式 uboot1
2799+1 records in
2799+1 records out
1433456 bytes (1.4 MB, 1.4 MiB) copied, 0.124488 s, 11.5 MB/s
2799+1 records in
2799+1 records out
1433456 bytes (1.4 MB, 1.4 MiB) copied, 0.0984421 s, 14.6 MB/s
写入uboot.bin完成
开始写入镜像 haos_s905l3a_bigfs_cn-13.2.1.release.20241130_143341.4a4e7574c7.img.xz 到 emmc
=>写模式 冬瓜haos的标准镜像
2310856704 bytes (2.3 GB, 2.2 GiB) copied, 106 s, 21.8 MB/s
0+283075 records in
0+283075 records out
2345664512 bytes (2.3 GB, 2.2 GiB) copied, 110.875 s, 21.2 MB/s
完成写入镜像 haos_s905l3a_bigfs_cn-13.2.1.release.20241130_143341.4a4e7574c7.img.xz 到 emmc
请认真看清楚,确认你的机器的型号:
1 - cm311-1a-yst
2 - e900v22d-ds(降速版)
3 - e900v22d
4 - m401a,unt403a,b863av3.2-m
请输入冬瓜haos系统支持硬件的编号[1-4]: 4
=>选择了设备: s905l3a-m401a
GMT+8, 2026-1-11 16:21 , Processed in 1.635000 second(s), 11 queries , MemCached On.
