- 积分
- 387
- 金钱
- 341
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 387
- 金钱
- 341
- HASS币
- 0
发表于 2024-10-19 15:20:36
显示全部楼层
portainer启动不了,是不是先要安装DOCKER呀
ssl='false'
[cont-init.d] 00-global_var.sh: exited 0.
[cont-init.d] 01-custom_script.sh: executing...
[11:30:21] INFO: Execute /config/addons_autoscripts/portainerZH.sh if existing
[11:30:21] INFO: ... no script found
[cont-init.d] 01-custom_script.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 30-nginx.sh: executing...
[cont-init.d] 30-nginx.sh: exited 0.
[cont-init.d] portainer.sh: executing...
[11:30:24] FATAL: PROTECTION MODE IS ENABLED!
[11:30:24] FATAL:
[11:30:24] FATAL: To be able to use this add-on, you'll need to disable
[11:30:24] FATAL: protection mode on this add-on. Without it, the add-on
[11:30:24] FATAL: is unable to access Docker.
[11:30:24] FATAL:
[11:30:24] FATAL: Steps:
[11:30:24] FATAL: - Go to the Supervisor Panel.
[11:30:24] FATAL: - Click on this add-on.
[11:30:24] FATAL: - Set the 'Protection mode' switch to off.
[11:30:24] FATAL: - Restart the add-on.
[11:30:24] FATAL:
[11:30:24] FATAL: Access to Docker allows you to do really powerful things
[11:30:24] FATAL: including complete destruction of your system.
[11:30:24] FATAL: Please, be sure you know what you are doing before
[11:30:24] FATAL: enabling this feature (and this add-on)!
[11:30:24] FATAL:
[cont-init.d] portainer.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
