楼主: yinjiong
多M1支持来了!斐讯空气检测仪M1插件for HA 3.0.1
发表于 2018-5-13 15:40:39 | 显示全部楼层
谢谢分享了
shaa
发表于 2018-5-15 12:59:02 | 显示全部楼层
好用吗????
发表于 2018-5-15 13:42:12 | 显示全部楼层
看看學習token
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-5-15 21:40:17 | 显示全部楼层
2018-05-15 14:23:15 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.tokengetter fails
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
    self._validate_conn(conn)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
    conn.connect()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 337, in connect
    cert = self.sock.getpeercert()
  File "/usr/lib/python3.6/ssl.py", line 897, in getpeercert
    self._check_connected()
  File "/usr/lib/python3.6/ssl.py", line 861, in _check_connected
    self.getpeername()
OSError: [Errno 107] Socket not connected
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
    timeout=timeout
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 357, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/lib/python3.6/site-packages/urllib3/packages/six.py", line 685, in reraise
    raise value.with_traceback(tb)
    chunked=chunked)
    conn.connect()
    self.getpeername()
urllib3.exceptions.ProtocolError: ('Connection aborted.', OSError(107, 'Socket not connected'))
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state
    yield from self.async_device_update()
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 327, in async_device_update
    yield from self.hass.async_add_job(self.update)
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/sensor/PhicommTokenGetter.py", line 111, in update
    control_resp = requests.get('https://accountsym.phicomm.com/v1/accountDetail', headers=headers,timeout=10)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 72, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 490, in send
    raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', OSError(107, 'Socket not connected'))
求更新下~~~
发表于 2018-5-16 10:13:39 | 显示全部楼层
谢谢!!!
发表于 2018-5-16 15:54:21 | 显示全部楼层
楼主,你好。我想问下我M1插件都添加好了 数据正常显示。但是老是会提示
OSError: HTTPSConnectionPool(host='aircat.phicomm.com', port=443): Read timed out. (read timeout=3)
这个错误请他是什么问题呢?
发表于 2018-5-16 19:22:45 | 显示全部楼层
非常感谢,很需要这个
发表于 2018-5-17 23:28:58 | 显示全部楼层
发表于 2018-5-19 21:10:34 | 显示全部楼层
小白学习中
发表于 2018-5-20 00:15:11 | 显示全部楼层
谢谢你经验的分享,虽然还没看明白,但我会好好学习的
GMT+8, 2025-12-25 17:40 , Processed in 0.270579 second(s), 11 queries , MemCached On.
