楼主: yinjiong
多M1支持来了!斐讯空气检测仪M1插件for HA 3.0.1
发表于 2018-5-4 22:52:06 | 显示全部楼层
谢谢 分享
发表于 2018-5-5 09:12:42 | 显示全部楼层
发表于 2018-5-5 13:11:21 | 显示全部楼层
上车了个M1,来看看怎么接入,谢谢大神!
发表于 2018-5-5 18:35:47 | 显示全部楼层
还是大神多
发表于 2018-5-5 20:39:09 | 显示全部楼层
终于成功了,好开心
发表于 2018-5-5 22:40:32 | 显示全部楼层
感谢有您
发表于 2018-5-6 01:17:56 | 显示全部楼层
好牛的感觉,很不错
发表于 2018-5-6 10:52:21 | 显示全部楼层
来学习一下 十分感谢
发表于 2018-5-6 21:05:07 | 显示全部楼层
传感器没数据  日志提示这个什么意思
发表于 2018-5-6 22:35:12 | 显示全部楼层
提示这个错误是什么情况?
Log Details (ERROR)
Sun May 06 2018 22:33:06 GMT+0800 (中国标准时间)
Update for sensor.tokengetter fails
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 60, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/lib/python3.6/socket.py", line 745, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
    self._validate_conn(conn)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
    conn.connect()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 284, in connect
    conn = self._new_conn()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7fbb100a90>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
    timeout=timeout
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='accountsym.phicomm.com', port=443): Max retries exceeded with url: /v1/accountDetail (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fbb100a90>: Failed to establish a new connection: [Errno -3] Try again',))
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state
    yield from self.async_device_update()
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 327, in async_device_update
    yield from self.hass.async_add_job(self.update)
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/sensor/PhicommTokenGetter.py", line 111, in update
    control_resp = requests.get('https://accountsym.phicomm.com/v1/accountDetail', headers=headers,timeout=10)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 72, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='accountsym.phicomm.com', port=443): Max retries exceeded with url: /v1/accountDetail (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fbb100a90>: Failed to establish a new connection: [Errno -3] Try again',))
GMT+8, 2025-12-25 17:40 , Processed in 0.317294 second(s), 13 queries , MemCached On.
