查看: 5178|回复: 12
[求助] 魔百盒插U盘,怎么挂出来
发表于 2024-4-6 15:52:32 | 显示全部楼层 |阅读模式
在host是硬件里可以看到sda,用fdisk -l命令不能显示,请教一下怎么才能挂载出来。刷的是最新的东瓜haos最新版
 楼主| 发表于 2024-4-6 17:50:18 | 显示全部楼层
2024-04-06 17:45:38.670 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/004 - None
2024-04-06 17:45:39.687 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/sg0 - None
2024-04-06 17:45:39.695 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bsg/0:0:0:0 - None
2024-04-06 17:45:39.701 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/sda - /dev/disk/by-id/usb-AS_Mass_Storage-0:0
2024-04-06 17:45:39.708 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/sda1 - /dev/disk/by-id/usb-AS_Mass_Storage-0:0-part1
2024-04-06 17:45:39.767 INFO (MainThread) [supervisor.docker.addon] Added cgroup permissions 'b 8:0 rwm' for device /dev/sda to addon_7eca76cc_onenav
mitu 手机认证
发表于 2024-4-6 22:19:48 | 显示全部楼层
sudo mount /dev/sdb1 /mnt/usb
发表于 2024-4-6 22:34:49 | 显示全部楼层
haos,是不一样的,在samba easy nas里可以挂载
发表于 2024-5-18 23:52:34 | 显示全部楼层
samba easy nas在哪里哇?
发表于 2024-5-19 00:02:28 | 显示全部楼层
加载项商店,大佬厉害!
发表于 2024-6-23 12:04:42 | 显示全部楼层
大佬,挂载多个硬盘,是写sdb1,sdb2,sdb3这样吗
发表于 2024-6-23 12:58:33 | 显示全部楼层
你试一下,常规是可以的
发表于 2024-6-24 00:03:25 | 显示全部楼层
https://bbs.hassbian.com/forum.php?mod=viewthread&tid=13696
自动挂载  我现在用的这个  很好用
发表于 2024-6-24 08:34:10 | 显示全部楼层
冬瓜HA 发表于 2024-6-23 12:58
你试一下,常规是可以的
大佬,黑豹X2挂载内存卡失败,怎么搞?是U盘不需要权限,内存卡需要权限?
Local Disks mounting...
... mmcblk0p1 is a physical device
[08:28:56] INFO: Mounting mmcblk0p1 of type
mount: permission denied (are you root?)
[08:28:56] FATAL: Unable to mount local drives! Please check the name.
已经用这个方法解决了
HassOS内挂载USB硬盘,米家摄像头录像直接保存到SMB - 『HASS & HASSIO』开发综合讨论区 - 『瀚思彼岸』» 智能家居技术论坛 - Powered by Discuz! (hassbian.com)
GMT+8, 2026-1-29 09:55 , Processed in 1.577676 second(s), 11 queries , MemCached On.
