楼主: sunfang1cn
[插件集成] 一个利用TPI算法的更好的暖气温控器
发表于 2024-8-11 10:35:53 | 显示全部楼层
TPI算法是啥 我只知道PID调节  这两个有区别吗
发表于 2024-12-28 21:58:33 | 显示全部楼层
Platform error 'climate' from integration 'tpi_thermostat' - No module named 'homeassistant.components.mqtt.schemas'
ha 2024.4.3
日志: homeassistant.config
来源: config.py:1437
首次发生: 21:56:39 (1 全部发生)
上次记录: 21:56:39
Platform error: climate - No module named 'homeassistant.components.mqtt.schemas'
  File "/usr/src/homeassistant/homeassistant/config.py", line 1437, in _async_load_and_validate_platform_integration
    platform = await p_integration.integration.async_get_platform(domain)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1070, in async_get_platform
    platforms = await self.async_get_platforms((platform_name,))
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1145, in async_get_platforms
    import_future.result()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1133, in async_get_platforms
    platforms.update(self._load_platforms(platform_names))
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1060, in _load_platforms
    platform_name: self._load_platform(platform_name)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1232, in _load_platform
    cache[full_name] = self._import_platform(platform_name)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1264, in _import_platform
    return importlib.import_module(f"{self.pkg_path}.{platform_name}")
  File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 995, in exec_module
  File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
  File "/config/custom_components/tpi_thermostat/climate.py", line 8, in <module>
    from homeassistant.components.mqtt.schemas import MQTT_ENTITY_COMMON_SCHEMA
ModuleNotFoundError: No module named 'homeassistant.components.mqtt.schemas'
发表于 2025-1-7 10:22:06 | 显示全部楼层
这是通过出水温度设置到max/min来切换供热?
我是写了个脚本,根据目标温度和当前温度每10分钟调整一次出水温度,这样是让壁挂炉维持在一次最小火力持续燃烧
没算过哪种方式更省煤气....
发表于 2025-6-30 19:33:21 | 显示全部楼层
隔壁的王叔叔 发表于 2024-7-24 11:06
大佬是不是可以搞一个空调的tpi算法?根据室温调节空调?
同问,找到空调的tpi算法没
发表于 2025-7-1 10:22:15 | 显示全部楼层
guxingtianya 发表于 2025-6-30 19:33
同问,找到空调的tpi算法没
没有。。。。。。。。。。
发表于 2025-11-9 21:36:36 | 显示全部楼层
我也买了zxlch 大大的ebus协议的温控器,现在想请教一下tpi的使用,安装不上,能请教一下,Platform error 'climate' from integration 'tpi_thermostat' - Exception importing custom_components.tpi_thermostat.climate
发表于 2025-11-13 00:00:23 | 显示全部楼层
这个tpi算法能否扩大到分室控制?或者和中央集线盒配合使用
发表于 2025-12-3 23:39:29 | 显示全部楼层
sunfang1cn 发表于 2024-3-8 21:36
https://bbs.hassbian.com/forum.php?mod=viewthread&tid=19115
也是论坛网友做的。
你好,大佬,你这个插件如何启动吗?直接用?
发表于 2025-12-27 12:57:06 | 显示全部楼层
gql1223 发表于 2025-11-9 21:36
我也买了zxlch 大大的ebus协议的温控器,现在想请教一下tpi的使用,安装不上,能请教一下,Platform error  ...
大佬,tpi怎么知道安装上了吗?我都不知道是否起作用了
发表于 2025-12-27 12:58:30 | 显示全部楼层
dd102 发表于 2024-12-28 21:58
Platform error 'climate' from integration 'tpi_thermostat' - No module named 'homeassistant.componen ...
GMT+8, 2026-1-31 22:32 , Processed in 0.072101 second(s), 11 queries , MemCached On.
